Ring 'Connection reset by peer' error
Hi Folks,
Been using Ring for a while and get a number of these in my log. The ring loads a little slower than i’d like too, although does work in the HA UI (but would still like to get to the bottom of these errors as had them in the last few versions of HA).
I can’t tell if its related but also getting these (never really had Ring running without issues):
2018-09-14 02:01:03 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template last_ring, the state is unknown.
2018-09-14 02:01:03 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template last_motion, the state is unknown.
Currently 0.77.3
Docker on Synology
2018-09-14 02:57:31 ERROR (SyncWorker_8) [ring_doorbell] Error!! ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
2018-09-14 02:57:32 ERROR (MainThread) [homeassistant.helpers.entity] Update for binary_sensor.ring_driveway_motion fails
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 384, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 380, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
    response.begin()
  File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.6/http/client.py", line 258, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
    return self._sock.recv_into(b)
  File "/usr/local/lib/python3.6/ssl.py", line 1009, in recv_into
    return self.read(nbytes, buffer)
  File "/usr/local/lib/python3.6/ssl.py", line 871, in read
    return self._sslobj.read(len, buffer)
  File "/usr/local/lib/python3.6/ssl.py", line 631, in read
    v = self._sslobj.read(len, buffer)
ConnectionResetError: [Errno 104] Connection reset by peer
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
    timeout=timeout
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 367, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.6/site-packages/urllib3/packages/six.py", line 685, in reraise
    raise value.with_traceback(tb)
    chunked=chunked)
    response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
  File "/usr/src/app/homeassistant/helpers/entity.py", line 224, in async_update_ha_state
    yield from self.async_device_update()
  File "/usr/src/app/homeassistant/helpers/entity.py", line 353, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/binary_sensor/ring.py", line 109, in update
    self._data.check_alerts()
  File "/usr/local/lib/python3.6/site-packages/ring_doorbell/doorbot.py", line 41, in check_alerts
    self.update()
  File "/usr/local/lib/python3.6/site-packages/ring_doorbell/generic.py", line 44, in update
    self._get_attrs()
  File "/usr/local/lib/python3.6/site-packages/ring_doorbell/generic.py", line 76, in _get_attrs
    lst = self._ring.query(url).get(self.family)
  File "/usr/local/lib/python3.6/site-packages/ring_doorbell/__init__.py", line 188, in query
    req = self.session.get((url), params=urlencode(params))
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 525, in get
    return self.request('GET', url, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 495, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
if anyone has seen this or resolved it, would be great to know how you did it
same problem
ERROR (Thread-10) [ring_doorbell] Error!! (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
v. 0.78.3 running in rasbian stretch
