Ring Intercom - Door won’t open automatically (Siedle 1+n)
:question: Ring Intercom – Door won’t open automatically (Siedle 1+n)
Hi everyone,
I’m using three Ring Intercoms with different door systems, all connected to Home Assistant.
Each system uses the exact same automation to automatically unlock the door when someone rings.
Two systems work perfectly, but system 3 (Siedle HTS 811-0, digital 1+n) doesn’t open the door, even though the ring event is detected.
:wrench: Setup Overview
System Door Unit Intercom Type Signal Type Status
1 Gira 125003 Type 2 Analog 2-wire :white_check_mark: Works
2 Siedle AIB 150-01 Type 2 Analog 2-wire :white_check_mark: Works
3 Siedle HTS 811-0 Type 3 Digital 1 + n Bus :x: Doesn’t open
All devices are online, on the same Ring account, firmware up to date, with good Wi-Fi signal.
Manual operation through the Ring App works perfectly.
:gear: Home Assistant Automation (same for all)
alias: Auto-unlock on ring
  - platform: state
    entity_id: event.system3_ring
    to: "on"
  - service: button.press
      entity_id: button.system3_door_open
  - delay: "00:00:03"
:brain: Issue Description
  • The ring event (event.system3_ring) is correctly triggered and visible in Home Assistant.
  • The automation action (button.system3_door_open) also executes normally — shown in the trace.
  • The Ring App even displays “Door opened”.
  • But the physical door doesn’t unlock.
  • When I manually press the unlock button in Home Assistant or in the Ring App, the door opens instantly.
Everything else (connectivity, app control, manual button press) works fine —
only the automatic unlock sequence right after ringing fails on the Siedle 1+n system.
Has anyone else experienced this with Ring Intercom + Siedle HTS 811-0 (Type 3 / 1+n Bus) where the unlock command does not actually open the door even though all triggers fire correctly?
Thanks!
The only idea I got: have you tried a different delay for opening? Maybe the digital signal type blocks the outgoing opening signal, because it is still handling the incoming ring and the other two analog ones are just faster doing so?
