RMshebei Tuya Smart WiFi Breaker 4P100A Integration with Home Assistant + Solar Calculation + Complete Dashboard
:tv: Video explaining the entire system:
:sunny: Solar Energy Monitoring Project
Complete solar energy monitoring system using:
4P100A WiFi circuit breaker with bidirectional measurement
Dedicated smart meter for solar production
Home Assistant Utility Meter
Customized cards (Mushroom + Card Mod + Browser Mod)
Own automation for resetting the cycle Billing
The project automatically calculates:
Consumption
Production
Energy injected
Energy balance
Estimated bill amount
Without relying on automatic offset from the Utility Meter.
:gear: Equipment Used
RMshebei Tuya Smart WiFi 4P100A Circuit Breaker
Sonoff POWR2
:electric_plug: Integrations Used
:small_blue_diamond: Home Assistant
:small_blue_diamond: Browser Mod
:small_blue_diamond: Mushroom Cards
:small_blue_diamond: Card Mod
:bar_chart: What the project automatically calculates
:heavy_check_mark: Daily solar production
:heavy_check_mark: Monthly solar production
:heavy_check_mark: Annual solar production
:heavy_check_mark: Energy injected into the grid
:heavy_check_mark: Total household consumption
:heavy_check_mark: Automatic calculation of the bill amount (based on the configured kWh value)
:heavy_check_mark: Monthly balance in kWh
:heavy_check_mark: Accumulated energy balance
:heavy_check_mark: Monthly energy credit or debit
:arrows_counterclockwise: Cycle Closing (IMPORTANT)
This project does not use offset in the Utility Meter.
Invoice closing is performed through:
:heavy_check_mark: Customized automation
:heavy_check_mark: Controlled manual reset
:heavy_check_mark: Automatic execution on the defined day (e.g., the 25th at 11:59 PM)
This allows for:
Greater control over the billing period
Independence from the Utility Meter’s fixed cycle
Easy adjustment if the utility company changes the reading date
:dart: Project Differentiators
:heavy_check_mark: Fully modular system
:heavy_check_mark: Does not interfere with other cards using the same sensors
:heavy_check_mark: Centralized and organized reset
:heavy_check_mark: Easy adaptation to any kWh value
:heavy_check_mark: Structure ready for publication on GitHub
:file_folder: :one: sensors.yaml
:file_folder: Value of Production
# SENSORS (PLATFORM TEMPLATE)
sensors:
# SOLAR PRODUCTION (BASE)
weekly_solar_production:
friendly_name: "Weekly Solar Production"
unit_of_measurement: "kWh"
value_template: >
{{ states('sensor.sonoff_1000916c58_energy') | float(0) }}
# CURRENT CONSUMPTION TWO PHASES
current_network_consumption_kW:
friendly_name: "Current Network Consumption (kW)"
unit_of_measurement: "kW"
value_template: >
states('sensor.breaker_power_of_phase_a_2') | float(0)
states('sensor.breaker_power_of_phase_b_2') | float(0)
current_network_consumption_w:
friendly_name: "Current Network Consumption (W)"
unit_of_measurement: "W"
value_template: >
) * 1000
# COSTS (fixed base 1.11)
kWh_value:
friendly_name: "kWh Value"
unit_of_measurement: "R$/kWh"
value_template: "1.11"
monthly_consumption_cost:
friendly_name: "Monthly Consumption Cost"
unit_of_measurement: "R$"
value_template: >
{{ states('sensor.monthly_energy_consumption') | float(0) * 1.11 }}
monthly_production_cost:
friendly_name: "Monthly Production Cost"
value_template: >
{{ states('sensor.monthly_solar_production') | float(0) * 1.11 }}
monthly_injected_cost:
friendly_name: "Monthly Injected Cost"
value_template: >
{{ states('sensor.monthly_energy_injection') | float(0) * 1.11 }}
BALANCES
accumulated_energy_balance:
friendly_name: "Accumulated Energy Balance"
value_template: >
states('sensor.breaker_total_energy_2') | float(0)
states('sensor.breaker_total_production_2') | float(0)
account_balance_kwh:
friendly_name: "Account Balance (kWh)"
value_template: >
sta
