Roborock S5 Vacuum Brush is Blocked
After replacing the main brush on my vacuum I get the “main brush is blocked” error quite a bit. On the robot, if I press the center large button, it will resume the current room cleaning after the error.
Does anyone know what command I need to issue to the robot in home assistant to replicate this button press? If I do the start command, it just starts a new clean cycle and doesn’t resume the room it is on.
