Hi there,
I am trying to set up my Xiaomi Vacuum in Home Assistant. I am running the following configuration:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
customize: !include customize.yaml
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: notmydomain.nl
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
device_tracker:
- platform: asuswrt
interval_seconds: 10
consider_home: 5
yeelight:
devices:
192.168.1.51:
192.168.1.95:
192.168.1.126:
192.168.1.163:
192.168.1.161:
google_assistant:
project_id: notmyproject
service_account: !include homeassistant.json
report_state: true
exposed_domains:
- light
asuswrt:
host: 192.168.1.1
username: notmylogin
password: notmypassword
protocol: telnet
port: 23
Adding the following seems to break the configuration.
vacuum:
- platform: xiaomi_miio
host: 192.168.1.50
token: notmytoken
When I check the config using the config checker it spits out the following error in the log:
2020-02-09 21:03:05 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
errors = await async_check_ha_config_file(request.app["hass"])
File "/usr/src/homeassistant/homeassistant/config.py", line 805, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 162, in async_check_ha_config_file
hass, p_name
File "/usr/src/homeassistant/homeassistant/requirements.py", line 55, in async_get_integration_with_requirements
hass, integration.domain, integration.requirements
File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
return version(req.project_name) in req
File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3138, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
In fact, the server refuses to boot at all when I add this to the config. It then seems to be causing a lot of cascading errors (which I assume are irrelevant)
Does anybody have a clue what to do?
