Roborock Saros 10R vacuum or mop only
Just installed the Roborock integration for my new Saros 10R.
Everything works fine but i can’t figure out how to vacuum only or to mop only.
I saw some posts where you can sent a vacuum command but i can’t find any parameters for the saros10R.
Hey there
I have a Saros 20 where i have found out how to do it.
I have make a pdf file where you can see it. maybe it works on your Saros 10R
pdf is here
I will try that.
Thank you so much !!!
This is fantastic and works like a charm for me. Was looking for this for months. Thank you so much for sharing!
it does ? Do you have saros 10R ? For me it just blings bell, nothing else happends :confused:
action: vacuum.send_command
  entity_id: vacuum.saros_10r
  command: set_clean_motor_mode
  params:
    - fan_power: 104
      mop_mode: 300
      mop_power: 0
      water_box_mode: 200
With that command you only set settings on saros.
Thats why saros blings the bell. it say settings ok
you have to start saros after that with
action: vacuum.start
  entity_id: vacuum.saros_20_sonic_complete
change your entity_id to sarso entity you have
Aah yes, thank you for clarifying this to me :slight_smile:
ABSOLUTELY BRILLIANT! Worked perfectly on my Saros 10R… Thank you so much!
Here is commands to vacuum then mob
send settings first
  command: app_set_clean_sequence_type
  params:
    fan_power: 103
    mop_mode: 300
    mop_power: 1
    repeat: 1
    type: 1
    water_box_mode: 225
  device_id: your_saros_device_id
Send start after that
For full cleaning
  command: app_start
  params:
    clean_mop: 1
For room cleaning
  command: app_segment_clean
  params:
    - clean_mop: 0
      clean_order_mode: 0
      repeat: 1
      segments: [3]   # <---- your room or rooms
