I was always on the run in the morning, so I wanted a simple automation to start my Roborock vacuum cleaning routine without accessing the app.
So, I started working on an automation involving a 3 event button (single, double, long). Set up individual automation per event and it worked for a while.
Then my basic automation got messed up by my partner not using the button, but the dedicated app. So I added the vacuum state to the mix. Of course, the integration’s state machine is more complicated than I needed, so I added a synced helper to synchronize the automation and vacuum state machines.
I ended up with a simple to use yet powerful automation and thought I should share it with the community.
Long story short, my automation provides the following actions:
- Single click: Starts a user-defined action if the vacuum is not already cleaning. In my case, it’s a custom “app_segment_clean” routine repeated one time.
- Double click: Starts a user-defined action if the vacuum is not already cleaning. In my case, it’s the same custom “app_segment_clean” routine as for single click, but repeated three times.
- Long click: Send the vacuum to the docking station, stopping any cleaning activity in progress.
- Single click while a cleaning activity is in progress: Pauses the current activity.
- Single click while a cleaning activity is paused: Resumes the paused cleaning activity.
- If the vacuum is paused for more than a user-defined number of minutes, the automation will send it back to the docking station.
- Optional daily custom routine with custom trigger time.
- An automation Do Not Disturb mode, in case you want to block the automation at night. I needed this as I had a “curious” guest interacting with the button in the middle of the night and started a whole-house cleaning routine at 2:00 in the morning.
What you’ll need:
- A Roborock vacuum
- The Roborock integration
- An Input Select helper, with the following states: None, Cleaning, Paused
The action commands are similar to the ones you would use in the aforementioned integration.
Disclaimer:
- I only tested on my setup, so please test it on your setup before officially deploying it “in production”.
- Since my setup relies on Z2M, it only works for Z2M buttons for now. Sorry, ZHA is on my list, but if I waited until I had added everything I wanted in this automation, I would probably release it in 2036.
- There are duplications and limitations, mostly caused by my current skill level. I am interested in making this more easy to use and more bulletproof. Please bear with me.
Github link: Home Assistant Blueprint: Control Roborock vacuum with one button · GitHub
I’m looking forward to feedback and improvements, but please bear with me, I’m still new at it.
blueprint:
name: Vacuum control via one single button
description: The one vacuum control automation to rule them all, with the help of
just one button.
domain: automation
homeassistant:
min_version: 2024.6.0
input:
button_device:
name: Button to control vacuum with
description: This device will be used to control the vacuum
selector:
device: {}
vacuum_device:
name: Vacuum to be controlled
description: This device will be used for all cleaning activities in this automation.
selector:
device:
filter:
- integration: roborock
multiple: false
vacuum_state_entity:
name: Vacuum state entity
description: This entity will be used to sync the automation internal state
with the device state.
selector:
entity:
filter:
multiple: false
state_helper:
name: Vacuum state helper
description: This helper will be used for storing the current vacuum state.
selector:
entity:
filter:
- domain:
- input_select
multiple: false
single_click_action:
name: Single click action
description: Command to be run on single click
default: app_start
single_click_params:
name: Single click params
description: String to be provided as arguments for single click action
default: {}
selector:
object: {}
double_click_action:
name: Double click action
description: String to be run on double click
default: app_start
double_click_params:
name: Double click params
description: String to be provided as arguments for double click action
default: {}
selector:
object: {}
single_click_while_cleaning_action:
name: Single click action while cleaning
description: Command to be run on single click while vacuum is cleaning
default: app_pause
single_click_while_cleaning_params:
name: Single click while cleaning params
description: String to be provided as argument for single click action while
the vacuum is cleaning
default: {}
selector:
object: {}
single_click_while_paused_action:
name: Single click while paused action
description: Command to be run on single click while vacuum is paused
default: app_start
single_click_while_paused_params:
name: Single click while paused params
default: {}
selector:
object: {}
daily_cleanup_enabled:
name: Enable daily cleanup
description: Enabling this will launch a specific action + params at the designated
time
default: true
selector:
boolean: {}
daily_cleanup_action:
name: Daily cleanup action
description: Command to be run every day at the specified time
default: app_start
daily_cleanup_params:
name: Daily cleanup params
description: String to be provided as argument for daily cleanup action
default: {}
selector:
object: {}
daily_cleanup_time:
name: Time to run the daily task
description: Automatic cleanup is run at configured time
default: 09:00:00
selector:
time: {}
cleaning_idle_timer:
name: Cleaning idle timer
description: Time to wait in paused state until return to dock is initiated
default: 10
selector:
number:
min: 5.0
max: 15.0
mode: slider
step: 1.0
automations_stop_time:
name: Time to start Do Not Distub mode for this automation
description: Automation will not run after this time
default: '21:00:00'
selector:
time: {}
automations_start_time:
name: Time to stop Do Not Distrub mode for this automation
description: Automation will run only after this time
default: 08:00:00
selector:
time: {}
source_url: https://gist.github.com/codingPear/53147a53af9d37d7c3b3484f4b47010b/
triggers:
- domain: mqtt
device_id: !input button_device
type: action
subtype: single
trigger: device
- domain: mqtt
type: action
subtype: double
trigger: device
- domain: mqtt
type: action
subtype: long
trigger: device
- domain: mqtt
type: action
subtype: hold
trigger: device
- trigger: state
entity_id:
- !input vacuum_state_entity
to: returning
- trigger: state
entity_id:
to: cleaning
- trigger: state
entity_id:
to: paused
- trigger: state
entity_id:
to: paused
for:
hours: 0
minutes: !input cleaning_idle_timer
seconds: 0
- trigger: time
at: !input daily_cleanup_time
conditions:
- condition: time
after: !input automations_start_time
before: !input automations_stop_time
weekday:
- sat
- fri
- thu
- wed
- tue
- mon
- sun
actions:
- choose:
- conditions:
- condition: and
conditions:
- condition: trigger
id:
- button_single_click
- condition: state
entity_id: !input state_helper
state: None
sequence:
- action: vacuum.send_command
metadata: {}
command: !input single_click_action
params: !input single_click_params
device_id: !input vacuum_device
- action: input_select.select_option
metadata: {}
option: Cleaning
alias: Single press, vacuum docked
- conditions:
- condition: and
conditions:
id:
- button_double_click
- condition: state
state: None
sequence:
metadata: {}
command: !input double_click_action
params: !input double_click_params
metadata: {}
option: Cleaning
alias: Double press, vacuum docked
- conditions:
- condition: or
conditions:
id:
- button_long_click
id:
- button_hold_click
- condition: not
conditions:
- condition: state
state: None
sequence:
- action: vacuum.return_to_base
metadata: {}
data: {}
metadata: {}
option: None
alias: Long press, vacuum not docked
- conditions:
id:
- condition: state
state: Cleaning
sequence:
metadata: {}
command: !input single_click_while_cleaning_action
params: !input single_click_while_cleaning_params
metadata: {}
option: Paused
alias: Single press, vacuum cleaning
- conditions:
id:
- condition: state
state: Paused
sequence:
metadata: {}
command: !input single_click_while_paused_action
params: !input single_click_while_paused_action
metadata: {}
option: Cleaning
alias: Single press, vacuum paused
- conditions:
id:
- daily_cleanup_time_trigger
- condition: state
state: None
- condition: template
value_template: !input daily_cleanup_enabled
sequence:
metadata: {}
command: !input daily_cleanup_action
params: !input daily_cleanup_params
metadata: {}
option: Cleaning
alias: Daily cleanup
- conditions:
id:
- global_state_paused_long_time
sequence:
metadata: {}
data: {}
metadata: {}
option: None
alias: Vacuum idle
- conditions:
id:
- global_state_cleaning
sequence:
metadata: {}
option: Cleaning
alias: Vacuum state changed from app, cleaning
- conditions:
id:
sequence:
metadata: {}
option: Paused
alias: Vacuum state changed from app, paused
- conditions:
id:
- global_state_none
sequence:
metadata: {}
option: None
alias: Vacuum state changed from app, none
mode: single
Backlog:
Add a switch for enabling or disabling the daily routine.- Add a way to select weekdays to run the daily routine.
- Remove vacuum device and entity duplication. The user should only need to provide one or the other, not both.
- Add ZHA support.
Changelog:
- 2025-01-30: Fixed daily schedule bug.
- 2025-01-09: Added support for both Long and Hold events. Some buttons (looking and you, Sonoff) have the long event, while others (ex: Aqara, some Tuya ones) use the Hold event.
- 2024-12-27: Added option to disable scheduled daily cleanup. Added minimum Home Assistant version embedded in the blueprint details.
- 2024-12-25: Initial release
