Roborock Vacuum S5 Integration Problem
I was able to retrieve the token for my US-server Roborock S5 vacuum and the IP address but when I try to add it to HA, I get a Failed to Connect error. I have verified the token with 2 different tools as well as making sure the IP address is correct. I have not found a similar issue in the forums but was hoping to see if anyone has a way to get this working.
Thanks in advance!
are you using the roborock app or the MI app?
I use the Mi Home app.
the only thing i could suggest is maybe yours has been migrated to tuya. there is a tuya wrapper someone made. you can give that a try… search the forums
