RocketController Astra no entities
So i’ve installed ESPHome to my RocketController Astra. I’ve set up yaml as per example on their website…
My yaml looks like this:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
status_led:
  pin:
    number: GPIO4
    inverted: true
output:
  - platform: ledc
    pin: GPIO12
rtttl:
  output: rtttl_out
# Enable Home Assistant API
api:
  encryption:
    key: "yGbzsvR2ScLqJlIg7N/EDeriqBBDJuA7F4rf8S4Xq4g="
ota:
  password: "0d1d59bdfce88a00244e442d6abc60e3"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Rocketcontroller"
    password: "ghM9LNRMA0Yo"
captive_portal:
web_server:
  port: 80
remote_receiver:
  pin: GPIO27
  dump: rc_switch
  # Settings to optimize recognition of RF devices
  tolerance: 50%
  filter: 50us
  idle: 4ms
  buffer_size: 2kb
switch:
  - platform: gpio
    pin: 25
  - platform: gpio
    pin: 26
  - platform: gpio
    pin: 33
  - platform: gpio
    pin: 32
binary_sensor:
  - platform: gpio
    pin:
      number: 34
      mode:
        input: true
  - platform: gpio
    pin:
      number: 35
      mode:
        input: true
  - platform: gpio
    pin:
      number: 36
      mode:
        input: true
  - platform: gpio
    pin:
      number: 39
      mode:
        input: true
  - platform: remote_receiver
    device_class: motion
    rc_switch_raw:
      code: "011100100110101000001000"
      protocol: 1
    on_press:
      then:
        - switch.toggle: relay1
    rc_switch_raw:
      code: "011100100110101000000100"
      protocol: 1
    on_press:
      then:
        - switch.toggle: relay2
    rc_switch_raw:
      code: "011100100110101000000010"
      protocol: 1
    on_press:
      then:
        - switch.toggle: relay3
    rc_switch_raw:
      code: "011100100110101000000001"
      protocol: 1
    on_press:
      then:
        - switch.toggle: relay4
    name: "Button ALL ON"
    rc_switch_raw:
      code: "000001000111010100000001"
      protocol: 1
    on_press:
      then:
        - switch.turn_on: relay1
        - switch.turn_on: relay2
        - switch.turn_on: relay3
        - switch.turn_on: relay4
    name: "Button ALL OFF"
    rc_switch_raw:
      code: "000001000111010100000010"
      protocol: 1
    on_press:
      then:
        - switch.turn_off: relay1
        - switch.turn_off: relay2
        - switch.turn_off: relay3
        - switch.turn_off: relay4
And my logs:
INFO ESPHome 2023.12.7
INFO Reading configuration /config/esphome/rocketcontroller.yaml...
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from 192.168.1.101 using esphome API
INFO Successfully connected to rocketcontroller @ 192.168.1.101 in 0.172s
INFO Successful handshake with rocketcontroller @ 192.168.1.101 in 0.113s
[17:42:22][I][app:102]: ESPHome version 2023.12.7 compiled on Jan 19 2024, 17:38:11
[17:42:22][C][status_led:019]: Status LED:
[17:42:22][C][status_led:020]:   Pin: GPIO4
[17:42:22][C][wifi:573]: WiFi:
[17:42:22][C][wifi:405]:   Local MAC: E4:65:B8:83:63:28
[17:42:22][C][wifi:410]:   SSID: [redacted]
[17:42:22][C][wifi:411]:   IP Address: 192.168.1.101
[17:42:22][C][wifi:413]:   BSSID: [redacted]
[17:42:22][C][wifi:414]:   Hostname: 'rocketcontroller'
[17:42:22][C][wifi:416]:   Signal strength: -63 dB ▂▄▆█
[17:42:22][C][wifi:420]:   Channel: 11
[17:42:22][C][wifi:421]:   Subnet: 255.255.255.0
[17:42:22][C][wifi:422]:   Gateway: 192.168.1.1
[17:42:22][C][wifi:423]:   DNS1: 192.168.1.1
[17:42:22][C][wifi:424]:   DNS2: 0.0.0.0
[17:42:22][C][logger:439]: Logger:
[17:42:22][C][logger:440]:   Level: DEBUG
[17:42:22][C][logger:441]:   Log Baud Rate: 115200
[17:42:22][C][logger:443]:   Hardware UART: UART0
[17:42:22][C][ledc.output:164]: LEDC Output:
[17:42:22][C][ledc.output:165]:   Pin GPIO12
[17:42:22][C][ledc.output:166]:   LEDC Channel: 0
[17:42:22][C][ledc.output:167]:   PWM Frequency: 1000.0 Hz
[17:42:22][C][ledc.output:168]:   Bit depth: 16
[17:42:22][C][switch.gpio:068]: GPIO Switch 'Relay 1'
[17:42:22][C][switch.gpio:091]:   Restore Mode: always OFF
[17:42:22][C][switch.gpio:031]:   Pin: GPIO25
[17:42:22][C][switch.gpio:068]: GPIO Switch 'Relay 2'
[17:42:22][C][switch.gpio:031]:   Pin: GPIO26
[17:42:22][C][switch.gpio:068]: GPIO Switch 'Relay 3'
[17:42:22][C][switch.gpio:031]:   Pin: GPIO33
[17:42:22][C][switch.gpio:068]: GPIO Switch 'Relay 4'
[17:42:22][C][switch.gpio:031]:   Pin: GPIO32
[17:42:22][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'SWITCH 1'
[17:42:22][C][gpio.binary_sensor:016]:   Pin: GPIO34
[17:42:22][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'SWITCH 2'
[17:42:22][C][gpio.binary_sensor:016]:   Pin: GPIO35
[17:42:22][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'SWITCH 3'
[17:42:22][C][gpio.binary_sensor:016]:   Pin: GPIO36
[17:42:22][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'SWITCH 4'
[17:42:22][C][gpio.binary_sensor:016]:   Pin: GPIO39
[17:42:22][C][rtttl:029]: Rtttl
[17:42:22][C][remote_base:123]: Remote Receiver Binary Sensor 'Button A'
[17:42:22][C][remote_base:123]:   Device Class: 'motion'
[17:42:22][C][remote_base:123]: Remote Receiver Binary Sensor 'Button B'
[17:42:22][C][remote_base:123]: Remote Receiver Binary Sensor 'Button C'
[17:42:22][C][remote_base:123]: Remote Receiver Binary Sensor 'Button D'
[17:42:22][C][remote_base:123]: Remote Receiver Binary Sensor 'Button ALL ON'
[17:42:22][C][remote_base:123]: Remote Receiver Binary Sensor 'Button ALL OFF'
[17:42:22][C][remote_receiver.esp32:054]: Remote Receiver:
[17:42:22][C][remote_receiver.esp32:055]:   Pin: GPIO27
[17:42:22][C][remote_receiver.esp32:060]:   Channel: 0
[17:42:22][C][remote_receiver.esp32:061]:   RMT memory blocks: 3
[17:42:22][C][remote_receiver.esp32:062]:   Clock divider: 80
[17:42:22][C][remote_receiver.esp32:063]:   Tolerance: 50%
[17:42:22][C][remote_receiver.esp32:064]:   Filter out pulses shorter than: 50 us
[17:42:22][C][remote_receiver.esp32:065]:   Signal is done after 4000 us of no changes
[17:42:22][C][captive_portal:088]: Captive Portal:
[17:42:22][C][web_server:168]: Web Server:
[17:42:22][C][web_server:169]:   Address: rocketcontroller.local:80
[17:42:22][C][mdns:115]: mDNS:
[17:42:22][C][mdns:116]:   Hostname: rocketcontroller
[17:42:22][C][ota:097]: Over-The-Air Updates:
[17:42:22][C][ota:098]:   Address: rocketcontroller.local:3232
[17:42:22][C][ota:101]:   Using Password.
[17:42:23][C][api:139]: API Server:
[17:42:23][C][api:140]:   Address: rocketcontroller.local:6053
[17:42:23][C][api:142]:   Using noise encryption: YES
Any ideas why am i not getting any entities ?
Thank you!
