I have two roller blinds controlled by the Smartlife app. Everything is working fine in the app.
In HA, everything is working but in reverse.
They show the state correctly in the smart life app but show the opposite state in HA.
I can reverse the direction in home assistant so that they show the right state but then the physical buttons are wrong.
To open the curtain in HA, I need to click the down arrow, and to close it, it’s the opposite. The movement is reversed.
This may have been discussed before, but I couldn’t find it.
Has anyone had this issue and resolved it?
Thanks, everyone.
I haven’t seen any posts about it. If it’s a known issue, someone might have a ready-made solution for it.
But if you need to work around it yourself, you could create a Template Cover in Home Assistant and just have it make the correct calls. Then you can use the Template Cover to control from Home Assistant.
I simply forgot about the app and reversed the direction in HA. Everything is correct, except in the app, which I don’t use, but it’s not difficult to use reversed.
I just had to change the routines I had on Alexa to get it to do the correct thing. I don’t know how to end this discussion.
