Roof windows and cover visualization/control
I have some Velux roof windows and covers.
And I wanted to have a nice visualisation of their state and a way to easily control them. The default mdi icons are IMO not intuitive and very limitted, so I created my own icons and card with custom:button-card.
Further I created some automations to control each window resp. cover with a single button:
  • If a window is closed or closing, a button press makes it to get opened.
  • If a window is open or opening, a button press makes it to get closed.
Here the SVG files to show the open, close and moving states:
Windows:
Covers:
The button card looks as following:
Windows:
type: custom:button-card
entity_picture: |
  if (entity.state == "unavailable") {
   return "/local/custom_icons/velux/roof-window-disabled.svg";
  else if (entity.state == "open") {
   return "/local/custom_icons/velux/roof-window-open.svg";
  else if (entity.state == "closed") {
   return "/local/custom_icons/velux/roof-window-closed.svg";
  else if (entity.state == "opening") {
   return "/local/custom_icons/velux/roof-window-opening.svg";
  else if (entity.state == "closing") {
   return "/local/custom_icons/velux/roof-window-closing.svg";
show_entity_picture: true
show_state: true
show_name: false
state_display: |
     return "nicht verfĂĽgbar";
    if (entity.attributes.current_position == 100) {
      return "Offen";
    else
     return (entity.attributes.current_position + "% offen");
    return "Geschlossen";
    return "Ă–ffnend";
    return "Schliessend";
styles:
  state:
    - font-size: 12px
entity: cover.room1
tap_action:
  action: call-service
  service: automation.trigger
  service_data:
    entity_id: automation.toggle_room1_window
Covers:
entity_picture: |
    return "/local/custom_icons/velux/roof-cover-disabled.svg";
    return "/local/custom_icons/velux/roof-cover-open.svg";
    return "/local/custom_icons/velux/roof-cover-closed.svg";
    return "/local/custom_icons/velux/roof-cover-opening.svg";
    return "/local/custom_icons/velux/roof-cover-closing.svg";
show_state: true
show_name: false
state_display: |
      return "Offen";
    else
      return (100 - entity.attributes.current_position + "% geschlossen");
    return "Ă–ffnend";
styles:
  state:
    - font-size: 12px
entity: cover.room1
tap_action:
  service_data:
    entity_id: automation.toggle_room1_cover
And the automation looks as following:
alias: Toggle Room1 Window
description: ""
triggers: []
conditions: []
actions:
  - if:
      - condition: or
        conditions:
          - condition: state
            entity_id: cover.room1_window
            state: closed
          - condition: state
            state: closing
    then:
      - device_id: 202576afc097***
        domain: cover
        entity_id: 46d90edfd2fb9***
        type: open
    else:
      - condition: or
        conditions:
          - condition: state
            state: open
          - condition: state
            state: opening
        domain: cover
        type: close
mode: single
The SVG files must be placed under www, eg. www/custom_icons/velux/. Since I can’t upload the SVG files here, I placed them here: Homeassistant: Create a nice roof window and cover visualization/control – Digital home of George Ruinelli
Hi.
I just stumbled upon this and 1st of all “Thank You” for this nice work of yours.
I would like to propose a small enhancement.
Velux windows have a “Ventilation” position. ( at least mine have)
This is when, the vent is open, but the window itself is closed.
The maximum venting value seems to be at: “Open - 15%”
So everything > 0 and <=15% should be considered “VENTING”
Only when fully closed, the windows reports “Closed”
Modifying your code slightly.
In the entity_picture:
entity_picture: |
if (entity.state == “unavailable”) {
return “/local/custom_icons/velux/roof-window-disabled.svg”;
else if (entity.state == “open”) {
if (entity.attributes.current_position <= 15) {
return “/local/custom_icons/velux/roof-window-venting.svg”;
else
return “/local/custom_icons/velux/roof-window-open.svg”;
else if (entity.state == “closed”) {
return “/local/custom_icons/velux/roof-window-closed.svg”;
else if (entity.state == “opening”) {
return “/local/custom_icons/velux/roof-window-opening.svg”;
else if (entity.state == “closing”) {
return “/local/custom_icons/velux/roof-window-closing.svg”;
and in the state_display:
state_display: |
return “unavailable”;
return “venting”;
else if (entity.attributes.current_position == 100) {
return “open”;
else
return (entity.attributes.current_position + “% open”);
return “closed”;
return “opening”;
return “closing”;
To have an additional SVG icon would also be nice.
I have not made a new icon, but propose the icon name :slight_smile:
Cheers and thanks for your efforts
Jurgen
Hi @juergen3
Thanks for your feedback!
What about this:
You can grab it from my homepage (see link in my first post)
Please note that the venting position seems not to be identical for everybody. On my windows, it is at 7 %!
Hi and thank you for the icon. :slightly_smiling_face:
About the venting position:
I checked again using the Velux KLR 200 and HA
I think you are right!
  1. up to 7% the window is venting but still “locked”
  2. between 8% and 14% it is venting and about to un-lock?
  3. at 15% the window is venting, still closed, but now “un-locked”
I considered <=15% as closed. :thinking:
Maybe we need more icons and states-displays?
How about:
  1. Venting $%" & locked
  2. Venting & un-locking
  3. Venting & un-locked
I am very bad at drawing icons :frowning: ,
but I think the propeller icon suggest a “forced or active” venting.
I suggest adding symbols to the window icon like
  1. wave arrows and a lock (<=7%)
  2. wave arrows and an unlocking lock (8%-14%)
  3. wave arrows and an un-locked lock (15%)
  4. above 15% - as before
For example something like this?:
Again, thanks for all your efforts
Best regards and cheers from the cold NAMIBIA
Jurgen
thanks for the great work - really love the icons! I have one request: the background of my dashboard is not white (but black) and some of the icons (e.g. roof-window-closing.svg) have still (partial) white backgrounds. May you re-upload them with complete transparent background?
Again, thanks!
