@Markus99 - Inovelli is a good brand. I am familar with them, just hadn’t done their route due a few stoppers here and there. But I do keep them in mind on occasion.
@Troon How do they hook into HA? I don’t see an integration for them. Or am I seeing this right, they support MQTT? Now THAT would be perfect (I was actually hoping for an MQTT option). Although, UK based is a downer. Hmm. How is the shipping to the US?
@kurtj Integration with deconz? That’s a hardware doggle that integrates with HA? I do have a Aeotec Z-Stick, but I hadn’t actually leveraged any z-wave devices, yet…
Manual is here: cleverly, the device sends updates when the temperature or humidity changes by a certain amount, rather than using power to run the wifi to tell you nothing’s changed just because 30s has passed.
Yes, MQTT is supported and a great way to use Shelly devices. Disables the cloud connection, too: what’s not to like?
As francisp, I use my Xiaomi temperature/pressure/humidity devices (LLKZMK11LM) with zigbee2mqtt.
I have one in pretty much every room and two outside the house and they have been working reliably, some for over a year now.
zigbee2mqtt allows you to also monitor the battery and the link quality to fine tune its location.
Can’t really comment on Zwave vs Zigbee, I never tried Zwave. I started out with a Philips Hue bridge, then migrated to Conbee/Deconz cause all bulbs were already Zigbee, and Deconz has better compatibility then Philips imho.
I have built some sensors myself using ESPHome, one with a DHT22, and one bluetooth over the ESP32. Both still work great but can’t really leave these all over the house…
The bluetooth one as one advantage I could not find in Zigbee, comes with a nice lcd display (Xiaomi Mijia bluetooth Temperature Humidity Sensor) Still looking for one like this that works with Zigbee though!
My house is full of esp8266 based multi sensors. I’m using a dht22 along with a pir motion and a lux sensor shoehorned into little project boxes and screwed to the ceiling. They are discrete, report almost instantly, and it was fun as hell putting them all together. ESPHome is also one of the coolest pieces of software I’ve ever played with. I just love it so much!
Got mine from Amazon. They were available in a five pack for like $11 but now all they have are 2 packs for $8. Still worth it. They are only available in black so I primed and painted them. All in I’m at like $15 a sensor. The esp’s were causing the motions to go crazy and throw constant false positives, but dropping the wifi signal strength to 10db got rid of all of them.
Wire it up and cram it all in your box, flash with esphome, then OTA the final esphome program. My basic code is shown below. Key points: I needed to drop the esp radio output power to keep the motion sensors from blowing up with false positives. I also have the motion on D0 and am pulling it down in an attempt to stop the false positives. I’m now thinking this is not needed though. I’m also averaging values to normalize the output. And i found i needed to calibrate my DHT’s to get accurate temp readings.
I really like the Xiaomi temp/humidity/pressure sensors. You can get them at Aliexpress. They work very well with deCONZ and the USB Conbee II. Super easy to configure. And the batteries last a very long time. I think you can get a pack of 4 for something like USD$45.
I can smell a little new project emerging never worked with the esp8266 before except from trying to flash a blitzwolf plug (need to solder the pins in order to get it going) Tried some clips like these clips but no avail, gonna need to solder…
I like the ESP ideas, but a little too DIY for me, right now.
Certainly going to give this a shot - I have Hues (only Zigbee devices we have), but would be nice to centralize these a bit.
Several of you have mentioned Xiaomi, but I’m having trouble actually finding (or understanding?) them. The model mentioned by @bigramon, LLKZMK11LM, is a controller? Their Amazon product page is not an LLKMZ11LM. It also says a Aqara Hub is required - is this what ConBee 2 will be supplementing?
I’m like the approach of MQTT - so I’ll either do zigbee2mqtt or go for Shelly H&T.
To recap this thread, the different levels of DIY are (most → least): ESPHome → Ziaomi + deCONZ/zigbee2mqtt → Shelly H&T → Wireless Tags (wifi, network polling), SmartThings sensors (e.g. Inovelli and Aeotec - Z-Wave).
The H&T will report back when the temp and/or humidity changes. You can set as to how much. Other than that it sleeps and does not report in (that’s how it saves battery). I’ve had mine for about 2 weeks and I have it sent to report back when there is a 1 degree or 1 percent change so I can get as much data as possible. It’s reporting via MQTT.
I migrated all my Philips bulbs to deconz and never looked back. I even sold the hue hub now.
It’s said that it’s better to separate ZLL (lights such as the Philips) and ZHA (sensors such as the Xiaomi ones, switches like the Ikea ones etc.) devices on a separate mesh, however I din’t have any issue running them on the same mesh for the last 2 years or so.
