I have two instances of Room Assistant in a cluster, one running on a Pi Zero W, and one running on Home Assistant itself.
The instance on the Pi Zero is running fine and updates as I go in and out of range.
The instance running on Home Assistant appears to be running fine as per the log file but normally displays the status of devices as ‘not home’. If left for some time I notice it occassionaly updates and shows the correct status, but mostly it doesn’t.
The Galaxy A31 is within range of the Garage Room Assistant which is hosted on the Pi Zero and shows its running as expected.
The iPhone is sitting right beside the Home Assistant (RPi4) running Room Assistant as an add on but detects as not_home its been sitting beside it for over an hour.
