Hope someone can help I want to setup Alexa to notify me if the bedroom temp is greater than 21°c at 20:00 but only if over 21c. I already have Alexa notification setup & am using Tado radiator valves for temperature. The attached just announces on Alexa even if temp is not over 21 thanks
Please copy/paste your automation between ``` 's using the “Edit it in YAML” option found under the meatball menu in the top right corner of the Automation editor so that we don’t have to rewrite your automation.
As it stands, your trigger is set to fire every time the temp goes from below 24 to above 24 (no matter what time it is) and at 17:59 everyday (no matter what the temp is).
Many thanks. Sorry I was doing some testing when I did the screen shot. This is the Yaml.
alias: Bedroom temp Turn on Air con
description: ‘’
- type: temperature
platform: device
device_id: e5ff292e5cc2838adbda6e35edf48377
entity_id: sensor.master_bedroom_temperature
domain: sensor
above: 21 - platform: time
at: ‘20:00:00’
condition: []
action: - service: input_text.set_value
value: idle
entity_id:
- input_text.air_con - service: notify.alexa_media_paul_s_2nd_echo_dot
type: tts
message: Turn on the Air conditioning - service: notify.alexa_media_paul_4_echo_dot
type: tts
message: 'Turn on the air conditioner ’
mode: single
description:
- platform: time
at: '20:00:00'
condition:
- condition: numeric_state
above: 21
value: idle
entity_id: input_text.air_con
type: tts
message: Turn on the air conditioner
type: tts
mode: single
FWIW, you can combine the two notify actions by using a less specific service and providing both Echos as targets:
type: tts
- media_player.paul_4_echo_dot
- media_player.paul_s_2nd_echo_dot
Many thanks for the quick & helpful reply, that worked. I’m learning new things. Thanks again.
