Roomba Sensor Template help
I´ve tried to create a sensor template for the first time for my roomba, to see wether the trash bin is full empty.
Right now, the bin is full, but the sensor tells me still empty. Have I missed something?
This is the code
  vacy_trash:
    friendly_name: "Vacy Bin"
    value_template: >-
      {% if ('states.vacuum.vacy.attributes.bin_full', 'false') %}
        empty
      {% else %}
        full
      {% endif %}
    icon_template: >-
        mdi:delete-outline
      {% else %}
        mdi:delete
      {% endif %}
Specify the entity that Home Assistant should monitor. Also modify the test used to determine if the attribute is false.
  vacy_trash:
    entity_id: vacuum.vacy
    value_template: >-
      {% if is_state_attr('vacuum.vacy', 'bin_full', 'false') %}
        empty
      {% else %}
        full
      {% endif %}
    icon_template: >-
        mdi:delete-outline
      {% else %}
        mdi:delete
      {% endif %}
For more information see:
It can also be reduced to:
  vacy_trash:
    value_template: >-
      {{ 'full' if is_state_attr('vacuum.vacy', 'bin_full', 'true') else 'empty' }}
    icon_template: >-
      {{ 'mdi:delete' if is_state_attr('vacuum.vacy', 'bin_full', 'true') else 'mdi:delete-outline' }}
EDIT
Fixed silly mistakes.
no need for ‘then’ is there?
vacy_trash:
    value_template: >
      {% if is_state_attr('vacuum.vacy', 'bin_full', 'false') %} empty
      {% else %}  full
      {% endif %}
    icon_template: >
      {% if is_state_attr('vacuum.vacy', 'bin_full', 'false') %} mdi:delete-outline
      {% else %} mdi:delete
      {% endif %}
also, in the short notation, you need an ‘if’ there don’t you?
 vacy_trash:
    value_template: >
    icon_template: >
in both templates the entity_id can be left out probably.
Yep, thanks. I wasn’t paying much attention to the first version of the template and was more focused on the reduced version.
Thanks guys, it´s working!
