Rooms sync HA and Google Assistant
when i configure the rooms on a device or an entity, this will sync with the first Sync from HA to Google Assistant. THen, when i change a room or move a device from one room to another, this will not sync to google ASsistant.
Does anybody knows this Problem?
Is it a bug?
Thanks for Help.
Regards,
Herbert
There is no concept of room in home assistant, can you expand on what you’re talking about?
I mean Area’s in HA…
Just had this same issue with Google Home not using my areas as rooms there. For the ones with the same issue, if Google Home has multiple homes, it won’t use the areas of Home Assistant. If you’ve just 1 room, it works like a charm. Maybe someone has benefit of this reply :slight_smile:
