Hi, I have built EspHome device which control the lights with rotary encoder and it works fine. But I have another light nearby and I would like to control it with this encoder also, to be copy of this light. It doesn’t matter if it can be done with code in Esp or with HA automation, just want it to work
Share your current yaml. Don’t forget to include it in preformatted text
tags.
This is a part of the working light code.
light:
- platform: monochromatic
output: PWMbazen
- platform: rotary_encoder
min_value: 16
max_value: 100
pin_a:
number: 7
mode:
input: true
pullup: true
pin_b:
number: 5
mode:
input: true
pullup: true
restore_mode: ALWAYS_ZERO
on_clockwise:
- light.dim_relative:
relative_brightness: 2%
transition_length: 0.1s
brightness_limits:
min_brightness: 16%
on_anticlockwise:
relative_brightness: -2%
brightness_limits:
min_brightness: 16%
output:
- platform: ledc
pin: 11
power_supply: bazenPS
power_supply:
- id: 'bazenPS'
pin:
number: 3
enable_time: 1sec
binary_sensor:
- platform: gpio
pin:
number: 9
inverted: true
mode:
input: true
pullup: true
on_press:
then:
- light.toggle: lights_bazen
The simplest way is probably to create a binary sensor or switch - with a button or similar. Then change your yaml:
on_clockwise:
if:
condition:
switch.is_on: your_switch
then:
brightness_limits:
min_brightness: 16%
else:
brightness_limits:
min_brightness: 16%
# etc...
This will work if the other light is controlled by that ESPHome device.
If not - you can do this:
on_clockwise:
if:
condition:
then:
brightness_limits:
min_brightness: 16%
else:
- home assistant.action:
action: light.turn_on
data_template:
entity_id: your_other_light
brightness_step_pct: 2
transition: 0.1
# etc...
Not tested - but you can see the docs yourself here:
and here:
one light is controlled with one Esp and other with other Esp
On esp where is a rotary encoder it works like this: light is off and when I rotate it clockwise it goes on and turn bightness up. On counter clockwise it decrease brightness until it shutdown the light. There is a push button on rotary encoder “Button bazen” which toggle light on/off. I want other light works the same, but controlled with encoder on this Esp unit. Is it possible to add automation on HA to adjust other light based on turning encoder on this ESP?
I used device group, you don’t have to rely on HA automation to sync the lights
That is what my second example above does…
You don’t need an automation on HA - the ESP can do it all.
If you want them to change at the same time, just remove the condition check.
I like this idea
Before I start with this, is it important in what Esp to put this code?
Is this only for two devices on one ESP or can be used for two different ESP controllers? I can’t put ESPHome entity id from another device in code because YAML says it couldn’t find this device ID.
I try this:
on_clockwise:
then:
brightness_limits:
min_brightness: 16%
then:
data_template:
entity_id: light.hallway_string_lights
transition: 0.1
but my YAML knowledge is not so good and can’t upload it to ESP
For both or more devices running esphome.
You basically just assign the same group for the light switch (with the rotary encoder) and lights. You can check the yaml examples on the github
Remove the second then:
Have put it like this:
on_clockwise:
then:
brightness_limits:
min_brightness: 16%
data_template:
transition: 0.1
but now it says:
on_clockwise:
then:
brightness_limits:
min_brightness: 16%
Unable to find action with the name 'home assistant.action'.
data_template:
transition: 0.1
- homeassistant.action:
A typo - sorry. I did say it wasn’t tested AND provided a link to the docs - where you would have spotted the problem.
I have added only this to the code:
external_components:
- source: github://cossid/tasmotadevicegroupsforesphome@main
components: [ device_groups ]
refresh: 10 min
device_groups:
- group_name: "testgroup1"
And now I get this when try to upload to my ESP:
Compiling .pioenvs/bazen-light/src/esphome/components/device_groups/device_groups.cpp.o
In file included from src/esphome/components/device_groups/device_groups.h:11,
from src/esphome/components/device_groups/device_groups.cpp:1:
src/esphome/components/device_groups/device_groups_WiFiUdp.h:15:7: error: redefinition of 'class IPAddress'
class IPAddress {
In file included from /data/cache/platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:170,
from src/esphome/core/macros.h:7,
from src/esphome/core/defines.h:2,
from src/esphome/core/application.h:6,
from src/esphome/components/device_groups/device_groups.h:3,
/data/cache/platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:29:7: note: previous definition of 'class IPAddress'
class IPAddress: public Printable
Compiling .pioenvs/bazen-light/src/main.cpp.o
*** [.pioenvs/bazen-light/src/esphome/components/device_groups/device_groups.cpp.o] Error 1
from src/esphome.h:21,
from src/main.cpp:3:
class IPAddress {
from src/esphome.h:2,
*** [.pioenvs/bazen-light/src/main.cpp.o] Error 1
========================= [FAILED] Took 14.41 seconds =========================
Can you share your yaml?
Sorry for delay of my reply but after a various try’s I came to only acceptable solution. It is here, it is a blueprint for automation that sync one light to another. It works just I want to
Might seem like an acceptable solution at first but, you’ll be disappointed eventually. The first time HA goes down then so does your quick fix blueprint with all the options for controlling the light or lights. Your best option is to always have a way to use Esphome by itself and then you can still use the blueprint if youd like but, doing the way you’re doing it now is not something id suggest.
Isn’t it strange that on HomeAssistant forum you suggest someone not to use HA automation?
It only seems strange because you’re in way over your head and dont know much yet. Secondly, this is an Esphome forum and in the Esphome and other specific forums, people typically come here because they are looking for an answer related to Esphome specifically and if not then they would ask it in the HA general discussion forum.
Maybe you made a wrong turn back there and got lost??
