Rotate camera rtsp stream using Frigate
Dear community,
I use avigilon cameras in the HA frigate integration. Unfortunately avigilon doesn’t support rotation of the rtsp stream. And I couldn’t find out how to rotate the image for the H5 dome cam in frigate using yaml code.
Does anyone know how to do that?
cameras:
  camera1:
    ffmpeg:
      inputs:
        - path: rtsp://USERNAME:[email protected]/defaultPrimary?streamType=u
          roles:
            - detect
    detect:
      enabled: True # <---- disable detection until you have a working camera feed
      width: 1280 # <---- update for your camera's resolution
      height: 720 # <---- update for your camera's resolution
    objects:
      track:
        - car
        - person
bests, Christian
it is recommended to use go2rtc config for the rotation and then access the stream in frigate
Hi!
that really doesnt work at all. There must be something I dont see…
go2rtc:
  streams:
    rtsp_wintergarten:
      - rtsp://USER:[email protected]/defaultPrimary?streamType=u
      - "ffmpeg:Cam_Wintergarten#video=h264#rotate=180"
cameras:
  Cam_Wintergarten:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/rtsp_wintergarten
          input_args: preset-rtsp-restream
          roles:
            - detect
    detect:
      enabled: True
      width: 1280
      height: 720
    objects:
      track:
        - car
        - person
    record:
      enabled: False
    snapshots:
      enabled: True
any mistakes in my code?
The stream is working! But the rotation still doesnt work.
bests, Christian
Number of mistakes:
  1. The ffmpeg stream is not referencing a stream that exists
  2. You need a separate stream named something else to reference directly
ok - you mean like that?
go2rtc:
  streams:
    rtsp_wintergarten:
    rtsp_wintergarten_rotated:
      - "ffmpeg:rtsp_wintergarten#video=h264#rotate=180"
cameras:
  Cam_Wintergarten_rotated:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/rtsp_wintergarten_rotated
          roles:
            - detect
    detect:
      enabled: True
      width: 1280
      height: 720
  Cam_Wintergarten:
    ffmpeg:
      inputs:
          roles:
            - detect
    detect:
      enabled: True
      width: 1280
      height: 720
    objects:
      track:
        - car
        - person
    record:
      enabled: False
    snapshots:
      enabled: True
If not - please could you correct the syntax for me? :slight_smile:
I’ve tried so many things that I dont know anymore what I’ve changed each try
bests, Christian
You need to make the names match between go2rtc and cameras config
well - I will rotate the lens on my cam. MUCH more easier and it will work for sure :slight_smile:
For anyone else happening by: I can confirm the above works. Helped me out to achieve the same thing to cover an alley way. You shouldn’t have given up!
Thanks to all.
@Dilligaf I am somewhat confused still
This is what I have:
go2rtc:
  streams:
    entrada:
      - rtsp://user:[email protected]/live
      - "ffmpeg:entrada#audio=opus"
    Entrada_Rotated:
      - "ffmpeg:entrada#video=h264#rotate=90"
  webrtc:
    candidates:
      - 10.69.69.72:8555
      - stun:8555
Then for the camera settings I have:
cameras:
  entrada:
    ffmpeg:
      inputs:
        - path: rtsp://user:[email protected]/live
          roles:
            - detect
    live:
      stream_name: Entrada_Rotated
    detect:
      width: 1080 # <---- update for your camera's resolution
      height: 1920 # <---- update for your camera's resolution
      fps: 7
    objects:
      track:
        - person
        - dog
        - cat
In frigate, when I view all cams, the entrada cam shows horizontal. When I click on it to view it live via frigate I do see it vertical. But pretty much that is the only place I see it vertical. Recordings are horizontal, and in HA cam view I also see it horizontal.
The example you give :
    ffmpeg:
      inputs:
          roles:
            - detect
Does that mean I should create a new camera like this:
Entrada_Rotated:
    ffmpeg:
      inputs:
        - path: rtsp://user:[email protected]/Entrada_Rotated
          roles:
            - detect
The 10.69.69.12 is the cameras IP, and it doesn’t have a rotated stream, so why would the Entrada_Rotated feed be tied to the cameras IP?
So I was on the right track, it wouldn’t make sense to get the rotated feed from the cameras IP, but turns out the 127.0.0.1 IS NOT A CAMERA IP. Assuming it is the local host IP, and I am picking up the rotated stream I created under go2rtc config.
This is the code I ended up with:
  Entrada_Rotated:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/Entrada_Rotated
          roles:
            - detect
And if it was a magic trick, I finally have vertical camera!
Seems a thread on the frigate github might be confusing many people, as it makes it seem you change the live view of the existing camera.
