Hello all
First let me apologise if the text below is not properly formatted. I am still trying to learn how to do it
The wake on lan works fine however the rpc shutdown does not
All my windows PCs do not need credentials to be accessed.
The only hardware that need credentials are the linux servers and pc .
What should i insert in this field?
what an i missing beside this
switch:
- platform: wake_on_lan
mac: 10:7B:44:50:33:80
host: 192.168.1.119
turn_off:
service: hassio.addon_stdin
addon: core_rpc_shutdown
input: HTPC
In the addon ```
address: 192.168.1.119
alias: HTPC
credentials: user%password
delay: 0
message: >-
Home Assistant is shutting down this PC. This cannot be canceled. Please
save your work!
I would like to add, that my requirement is to have the pcs shutdown at a specific time or following an trigger from an automation such as geofencing.
Hence In my opinion I would need 2 seperate switches one for wol and one for shutdown. Correct?
Hence I would would it look like something this?
switch:
- platform: rpc
mac: xxx
host:192.168.1.xxxx
cenentials: none
turn_off:
service: hasio_addon_stdin
addon: core_rpc_shtdown
input: HTPC
As I’m by no means a savvy IT individuals I understand the thas may be totally nonsense
If so My apologies
Thank you for your patience and any help you provide to set me straight
Reply
