Hi all,
Are there any changes between 4.17 and 5.10 that might impact my ability to use the RPi4 GPIO? Someone mentioned it in a comment on the release thread, but I can’t see anything mentioned elsewhere to back it up.
Specifically, I use a fan HAT to provide active cooling and I’d rather it wasn’t broken by the upgrade:
switch:
- platform: rpi_gpio
ports:
18: RPI Cooling Fan
climate:
- platform: generic_thermostat
name: RPI Cooling Fan Controller
heater: switch.rpi_cooling_fan
target_sensor: sensor.cpu_temp
min_temp: 55
max_temp: 80
ac_mode: true
target_temp: 65
cold_tolerance: 0.1
hot_tolerance: 0.1
min_cycle_duration:
seconds: 30
keep_alive:
minutes: 5
initial_hvac_mode: "cool"
Many thanks!
