Many updates , but no one interested in this problem ?
Or do someone have a solution to this ?
Updated to latest HassOS, but thinking of downgrading
@segwpe The problem is it looks like the creator of this addon has abandoned it, or at least hasnāt checked for awhile. Someone needs to fix the code and rebuild the package or else this will most likely be dead forever
After some effort (addons are new to me) found the Bug, Fixed it and submitted a Pull Request to @Pantomax
Bottom line: Hassio added Apparmor that now needs to be set to False to access GPIO pins for RF receiver.
Happy to report I now have a binary_sensor that can be toggled via RF Codeds received.
Hereās a link to the Code (pull request)
And documenation of setting Apparmor:False for Add-Ons
Fixed the issue. (see below). In mean time you can add this custom URL to install the fixes. Let me know how it works for you! https://github.com/fryguy04/hassio-addons
Just tested and it works. Thanks a lot.
Home Assistant 0.81.2, HassOS 1.12, Raspberry Pi 3 Model B + (ARMv8) (8024081)
Hiā¦sorry for my delayed answerā¦
Tested it and it workedā¦now I just need to get my weatherstation to connect
Great work in catching that AppArmor error. Now Iām wondering how I can use that addon to send codes? I have several cheap outlets that are controlled via 433MHz and I have sender and receiver both hooked up to my HassOS powered RPi 3B. I recall this was working with Hassio (not HassOS) without much trouble. I think I had to map the device inside the Docker container, but that was about all I had to configure. I recently changed to HassOS and only now I was realizing why my automations werenāt working anymore.
Hi
I have a fresh install of HASS.IO on my RPi 3B and have installed the Mosquito Core add-on and followed the instructions for the install. However, when starting the RPi RF receiver I see the error below in the logs. Any suggestions as to what might be wrong as I am running on a Raspberry Pi?
Using base prefix '/usr'
New python executable in /data/venv/bin/python3
Also creating executable in /data/venv/bin/python
Installing setuptools, pip, wheel...
done.
Running virtualenv with interpreter /usr/bin/python3
Collecting rpi-rf
Downloading https://files.pythonhosted.org/packages/e8/b4/092c00607f8e12670c0ac8cb9d4ec495952726105cc36c879825151630bf/rpi_rf-0.9.7-py3-none-any.whl
Collecting RPi.GPIO (from rpi-rf)
Downloading https://files.pythonhosted.org/packages/af/2f/407b6e4cc8a0bdf434825a160bba1807991886b63cce16a5f1a6e1f24cdf/RPi.GPIO-0.6.5.tar.gz
Building wheels for collected packages: RPi.GPIO
Running setup.py bdist_wheel for RPi.GPIO: started
Running setup.py bdist_wheel for RPi.GPIO: finished with status 'done'
Stored in directory: /root/.cache/pip/wheels/6d/fc/be/f0bd634b0033499def11c5c8b63731c3de443eed482dbe4c71
Successfully built RPi.GPIO
Installing collected packages: RPi.GPIO, rpi-rf
Successfully installed RPi.GPIO-0.6.5 rpi-rf-0.9.7
File "/share/rpi-rf_receive.py", line 15, in <module>
from rpi_rf import RFDevice
File "/data/venv/lib/python3.6/site-packages/rpi_rf/__init__.py", line 2, in <module>
from .rpi_rf import RFDevice
File "/data/venv/lib/python3.6/site-packages/rpi_rf/rpi_rf.py", line 9, in <module>
from RPi import GPIO
File "/data/venv/lib/python3.6/site-packages/RPi/GPIO/__init__.py", line 23, in <module>
from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
Updateā¦
Looks as though from other threads that GPIO may not be compatible with the 64-bit version of HassOS:
Anyone got an idea why I am getting thisā¦?
2019-03-08 05:09:40 - [INFO] rpi-rf_receive: 2 [pulselength 396, protocol 1]
Error: Connection refused
2019-03-08 05:09:43 - [INFO] rpi-rf_receive: 1048576 [pulselength 1783, protocol 4]
2019-03-08 05:09:44 - [INFO] rpi-rf_receive: 131080 [pulselength 958, protocol 2]
2019-03-08 05:09:44 - [INFO] rpi-rf_receive: 128 [pulselength 656, protocol 2]
2019-03-08 05:09:44 - [INFO] rpi-rf_receive: 524288 [pulselength 1838, protocol 4]
my configuration.yml
mqtt:
broker: core-mosquitto
port: 1883
username: homeassistant
password: qwer1234!@#$
rpi-rf_receive.py:
mosquitto_address = ā127.0.0.1ā
mosquitto_port = ā1883ā
mosquitto_user = āhomeassistantā
mosquitto_password = āqwer1234!@#$ā
And Mostquitto broker umā¦ componentā¦?
āloginsā: [
āusernameā: āhomeassistantā,
āpasswordā: āqwer1234!@#$ā
āanonymousā: false,
ācustomizeā: {
āactiveā: false,
āfolderā: āmosquittoā
ācertfileā: āfullchain.pemā,
ākeyfileā: āprivkey.pemā
nvm I got itā¦ itās combination of the the ip address and the USERNAME not being an actual user on my systemā¦
Ok I to am getting what seems like random data nowā¦ even when I use the transmitter that came with the receiverā¦ app armor is set to false for sureā¦ just checked the repo i pulled fromā¦ any clue? any one?
Does this have anything to do with the problem I am having??
1552081029: New client connected from 172.30.33.3 as mosqpub|187-de3cd379-rf (c1, k60, uāTrentā).
1552081029: Client mosqpub|187-de3cd379-rf disconnected.
1552081029: New connection from 172.30.33.3 on port 1883.
[INFO] found Trent on local database
1552081030: New client connected from 172.30.33.3 as mosqpub|188-de3cd379-rf (c1, k60, uāTrentā).
1552081030: Client mosqpub|188-de3cd379-rf disconnected.
1552081030: New connection from 172.30.33.3 on port 1883.
1552081030: New client connected from 172.30.33.3 as mosqpub|189-de3cd379-rf (c1, k60, uāTrentā).
1552081030: Client mosqpub|189-de3cd379-rf disconnected.
Any idea why this massively increases the size of the Hassio snapshot? Without this addon my snapshots are about 6MB. With this addon they are in excess of 210MB!
For anyone who is not aware of an alternative, or canāt get this to work on your setup.
https://www.itead.cc/wiki/Sonoff_RF_Bridge_433
Cheap, can be flashed with tasmota, decent range (although have not tested max range).
Currently using mine for the cheap Chinese 433 door bell, and some other 433 stuff.
I use OpenMqttGateway on nodemcu as a Rf to mqtt device. Fast and reliable
Never thought of using the bridge. Would you be able to recommend a good remote RF ?
I want to have a remote (or 2) I can use for turning vol up/down, advance next song, for my Sonos devices. Since Sonos app removed that ability from the lock screen on iOS and their app sometimes takes forever to open and connect to the speakers, I thought this would be a great alternative. Especially for when I have guests staying.
Thanks!
Hello, first of all thanks a lot for this script, I think we can do some awesome things with it
Iām running hassio on a pi 3+ and have the cheap receivers. Iām able to receive the code of my switch, unfortunately in super short range (ca. 30-50 cm). I added an antenna, tried 5V, 3.3V and voltage dividerā¦ I will buy the more expensive receiver, we will see.
Iām new to hassio and I canāt get the automation running.
I defined this in my configuration.yaml
vacuum:
- platform: xiaomi_miio
host: 192.168.178.73
token: 6b77793350577659736537655a5a314b
platform: mqtt
state_topic: āsensors/rf/receiverā
name: āRF Receiverā
this in my automation.yaml
- alias: 'Robo hello'
initial_state: 'on'
platform: mqtt
topic: "sensors/rf/receiver"
payload: '3880184'
- service: vacuum.locate
This is how the log of the script looks:
2019-05-11 11:36:27 - [INFO] rpi-rf_receive: 3880184 [pulselength 297, protocol 1]
This is what I got from MQTT, I finally added my main user to the rfi script since I could not get it running with the MQTT user I added.
[INFO] found steff on Home Assistant
1557567432: New client connected from 172.30.32.1 as mosqpub|194-de3cd379-rf (c1, k60, u'steff').
1557567432: Client mosqpub|194-de3cd379-rf disconnected.
Now I donāt know what is wrong or where to have a look.
Any help welcome
The biggest problem with this solution is the number of switches it controls. Iām already on my second and looking at maybe buying another one.
Are you using the stock firmware or a custom one?
Espurna
