Clean install, rpi4, conbee II.
Unable to see the ‘gateway’ from deconz/ phoscon
Log shows
21-10-19 15:36:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-19 15:36:32 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-10-19 15:36:32 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-10-19 15:36:32 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-19 15:36:32 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-19 15:36:35 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-10-19 15:36:35 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-19 15:36:57 WARNING (MainThread) [supervisor.api.ingress] Ingress for hxW2l4gd8a1RWuyZLsVea33EinHAXyeDKKuNJbA0UcI not available
Conbee log shows
3:41:47 PM – (ERROR) Zigbee Home Automation - message first occurred at 3:36:21 PM and shows up 8 times
Couldn't start application
3:41:47 PM – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy/application.py - message first occurred at 3:36:21 PM and shows up 8 times
No response to 'Command.read_parameter' command with seq id '0x02'
3:41:47 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py - message first occurred at 3:36:21 PM and shows up 8 times
Received message for unregistered webhook 24128bfceee1c5a63f3a2aae1837d54fb33e558bdfcca93e5b94fb3e556b5ef4 from 192.168.1.67
3:37:35 PM – (WARNING) Webhook - message first occurred at 3:37:35 PM and shows up 2 times
Config entry 'ConBee II, s/n: DE2449966 - dresden elektronik ingenieurtechnik GmbH' for zha integration not ready yet; Retrying in background
3:36:21 PM – (WARNING) config_entries.py
Ended unfinished session (id=6 from 2021-10-19 13:22:16.899342)
3:36:09 PM – (WARNING) Recorder
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
3:36:09 PM – (WARNING) Recorder ```
Suggestions please, I've tried everything I can think of.
