RPi4 Hassio Beta, any experience with it?
I’m currently running the RPi4 with Raspbian, but I would love to skip that, and just go with a HASSIO, but is it working properly yet? Or is it better waiting?
I’m using Hassio on RPi4 since yesterday no problem as now I can make the same as my RPi3b+
Great, thankyou Thomas. I’ll give it a go…
Good to hear it works, did you go 32 bit or 64 bit?
Hello the version 32 on RPi4 With 2gb
Very eager for this to come out of beta… I really really need the extra RAM.
The RPi 3B+ is barely enough for a medium size configuration, you install a few add-ons such as Unifi, Samba, Log viewer, SSH and Web Terminal, NGINX Proxy Manager and Google Drive Backup add-on and you’ll be using on average 75-80%, if it goes above 90% and sometimes the web interface goes down or the whole thing gets sluggish.
I turn off other add-ons all the time to conserve memory like the configurator or IDE, or I just uninstall them. Also I removed quite a few components as I was running out of RAM quite often. I know it has RAM management but it does some nasty things once it starts running out of RAM.
With this I can hopefully run PLEX and start adding more stuff.
I dont think that plex, transcoding and rpi4 is a good combi :hushed:, but I haven’t tried :wink:
Btw. running 64bit on 4 GB version of RPi4, with a 64 GByte SDCard, and an external MariaDB.
just as a side note, how did you set that up?
I have a NAS with a MariaDB, and then this in the configuration:
recorder:
  db_url: !secret mysqlconnection
  exclude:
    domains:
      - weblink
      - updater
      - group
      - input_boolean
      - input_number
      - input_select
      - input_player
      - weather
      - zone
    entities:
      - sun.sun
  purge_keep_days: 14
  purge_interval: 9
In Secrets.yaml, I then have:
mysqlconnection: mysql://user:pw@ip/dbname?charset=utf8
thanks, only 1 question and Ill stop diverging this thread: anything particular in the MariaDB settings on the NAS to allow HA connection?
Nope, user and db, phpadmin has a funktion for crearing a db for s user, and grant the user full rights for it
I’ve been running it for a week on a 1GB model. So far so good! It’s very fast.
I’m thinking on making the jump already. So is it ready for prime time? The Gigabit network adapter is a big deal for me.
Seems to be as ready as anything else we do. :slight_smile:
I’d say go for it!
