RPi5 Home Assistant Randomly Restarts
For 3 years I used home assistant with a RPi4, with DB MariaDB. A few months ago I switched to DB for SQLite. Last week I switched to a Raspberry Pi 5, hat, SSD, and power supply 27W. all new original Raspberry pi. I restored the backup and I am having trouble restarting randomly. The only errors I see are from the database.
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
Ended unfinished session (id=3 from )
It has happened to me that the database file was corrupted and I rebuilt the database again (original SQLite) and it happened again.
my file “home-assistant_v2.db”, after 3 days, is 64 Mb
temperature does not exceed 30 °C, and ram of 30%
Can someone help me?
Does the SSD have it’s own power supply ?
no. it’s the Raspberry hat and ssd 256GB NVMe 2230
i think we have the same problem here:
i even went to pick up a ssd kit today because i thought maybe its the sd cards…
we have a identical setup
I’ve gone 3 days without restarting, and I’ve restarted 3 days on the same day
yes also my rpi restarts and show the db error…
i created now a completely clean setup without restoring from any backup… lets see how it goes
