Hi
I can run a webradio from Another raspberry pi with omxplayer and it works greate.
But now I like to Control the radio with my Hassio and was thinking MQTT have to be a easy way.
So I did add a inject and MQTT node to make a test
and on the remote raspberry I have install Mosquitto and run this command mosquitto_sub -d -t Radio
I then got this response from Node-Red when I push the injector
It does response but maybe not like that I was hoping for. I was hoping for just a “ON” so I have to do something strange.
I also trying to make a script and I was going to try to use python 3 and I maybe have a idea how to do that but not sure if I can do that until I have fix the first problem so I can send a ON/OFF command tru mqtt
