Run action in parallel
I have the following automation for my sprinklers.
switch:
- platform: command_line
  switches:
    bw_beet_ost:
      friendly_name: Beete vorne
      command_on: "ssh pi2 -C /usr/local/bin/bus.py 35 18 1 1"
      command_off: "ssh pi2 -C /usr/local/bin/bus.py 35 18 1 0"
    bw_rasen_sued_ost:
      friendly_name: Rasen vorne/seite
      command_on: "ssh pi2 -C /usr/local/bin/bus.py 35 18 2 1"
      command_off: "ssh pi2 -C /usr/local/bin/bus.py 35 18 2 0"
    bw_hochbeet:
      friendly_name: Hochbeet
      command_on: "ssh pi2 -C /usr/local/bin/bus.py 35 18 3 1"
      command_off: "ssh pi2 -C /usr/local/bin/bus.py 35 18 3 0"
    bw_rasen_hinten:
      friendly_name: Rasen hinten
      command_on: "ssh pi2 -C /usr/local/bin/bus.py 35 18 4 1"
      command_off: "ssh pi2 -C /usr/local/bin/bus.py 35 18 4 0"
    bw_bambus_thujen_beeren:
      friendly_name: Bambus/Thujen/Beeren
      command_on: "ssh pi2 -C /usr/local/bin/bus.py 35 18 6 1"
      command_off: "ssh pi2 -C /usr/local/bin/bus.py 35 18 6 0"
    bw_blumenbeet:
      friendly_name: Blumenbeet
      command_on: "ssh pi2 -C /usr/local/bin/bus.py 35 18 5 1"
      command_off: "ssh pi2 -C /usr/local/bin/bus.py 35 18 5 0"
    bw_nebler_terrasse:
      friendly_name: Nebler Terrasse
input_slider:
  sprinklerhour:
    icon: mdi:timer
    initial: 6
    min: 0
    max: 23
    step: 1
  sprinklerminutes:
    icon: mdi:timer
    initial: 30
    min: 0
    max: 60
    step: 1
  bw_beet_ost:
    icon: mdi:timer-sand
    initial: 30
    min: 0
    max: 60
    step: 1
    initial: 30
    min: 0
    max: 60
    step: 1
  bw_blumenbeet:
    initial: 30
    min: 0
    max: 60
    step: 1
  bw_rasen_sued_ost:
    initial: 10
    min: 0
    max: 60
    step: 1
  bw_hochbeet:
    initial: 20
    min: 0
    max: 60
    step: 1
  bw_rasen_hinten:
    initial: 20
    min: 0
    max: 60
    step: 1
automation:
  - alias: 'Sprinkler Schedule'
    initial_state: false
       value_template: '{{ now().hour == (states.input_slider.sprinklerhour.state  | round(0))  and  now().minute == (states.input_slider.sprinklerminutes.state  | round(0) )  }}'
#Tropfschläuche
#bw_beet_ost
      - service: homeassistant.turn_on
          entity_id:
            - switch.bw_beet_ost
      - delay: '00:{{ states.input_slider.bw_beet_ost.state | int }}:00'
      - service: homeassistant.turn_off
          entity_id:
#bw_bambus_thujen_beeren
          entity_id:
            - switch.bw_bambus_thujen_beeren
      - delay: '00:{{ states.input_slider.bw_bambus_thujen_beeren.state | int }}:00'
          entity_id:
#bw_blumenbeet
          entity_id:
            - switch.bw_blumenbeet
      - delay: '00:{{ states.input_slider.bw_blumenbeet.state | int }}:00'
          entity_id:
#bw_hochbeet
          entity_id:
            - switch.bw_hochbeet
      - delay: '00:{{ states.input_slider.bw_hochbeet.state | int }}:00'
          entity_id:
#bw_rasen_sued_ost
          entity_id:
            - switch.bw_rasen_sued_ost
      - delay: '00:{{ states.input_slider.bw_rasen_sued_ost.state | int }}:00'
          entity_id:
#bw_rasen_hinten
          entity_id:
            - switch.bw_rasen_hinten
      - delay: '00:{{ states.input_slider.bw_rasen_hinten.state | int }}:00'
          entity_id:
which runs one sprinkler after another.
But I want to start some sprinklers in parallel, each for there own delay time, and after all of them are finished, continue with the others in serial.
Is there a way to do this?
I found a workaround and split the automation, all starting at the same time. The sprinkler which should run exclusively are added to the automation with the longest duration.
That’s working fine as long as this duration isn’t changed, so it’s working but not very sexy.
input_slider:
  sprinklerhour:
    icon: mdi:timer
    initial: 7
    min: 0
    max: 23
    step: 1
  sprinklerminutes:
    icon: mdi:timer
    initial: 0
    min: 0
    max: 60
    step: 1
  bw_beet_ost:
    initial: 20
    min: 0
    max: 60
    step: 1
    initial: 30
    min: 0
    max: 60
    step: 1
  bw_blumenbeet:
    initial: 20
    min: 0
    max: 60
    step: 1
  bw_rasen_sued_ost:
    initial: 10
    min: 0
    max: 60
    step: 1
  bw_hochbeet:
    initial: 0
    min: 0
    max: 60
    step: 1
  bw_rasen_hinten:
    initial: 20
    min: 0
    max: 60
    step: 1
automation:
- alias: 'Bewässerung bw_bambus_thujen_beeren_rasen'
  initial_state: true
  condition:
    condition: state
    entity_id: input_boolean.bw_on_off
    state: 'on'
        entity_id:
        entity_id:
        entity_id:
        entity_id:
        entity_id:
        entity_id:
- alias: 'Bewässerung bw_beet_ost'
  initial_state: true
  condition:
    condition: state
    state: 'on'
        entity_id:
        entity_id:
- alias: 'Bewässerung bw_blumenbeet'
  initial_state: true
  condition:
    condition: state
    state: 'on'
        entity_id:
        entity_id:
- alias: 'Bewässerung bw_hochbeet'
  initial_state: true
  condition:
    condition: state
    state: 'on'
        entity_id:
        entity_id:
