I’d like to have an input_select control (day/evening/night/auto) to override my heating settings.
I have an automation to set the temperature on my thermostats which is triggered by either a time trigger or by a state change of various input controls.
It basically looks like this:
- platform: time
- platform: state
- platform: state
The action: part calls a couple of climate.set_temperature services to set the temperatures.
My goal is now to reset the input_select control back to ‘auto’, if this automation was triggered by the time trigger (and not by changing the state of any of the input controls).
[homeassistant.bootstrap] Invalid config for [automation]: [condition] is an invalid option for [automation]. Check: automation->action->3->condition.
when validating the config.
The documentation is not clear if a condition can be applied to only a subset of the services called in the action: clause (i.e. the ones after the condition:).
Does anyone know the correct syntax? Or if it is supposed to work like this at all?
So the whole thing now looks like this for the “Evening” settings:
(“Day” and “Night” settings work accordingly)
alias: 'Heating Evening'
- platform: time
hours: 16
minutes: 00
seconds: 00
- platform: state
entity_id: input_slider.heating_livingroom_evening
- platform: state
entity_id: input_slider.heating_bedroom_evening
- platform: state
entity_id: input_slider.heating_office_evening
- platform: state
entity_id: input_boolean.venting
state: 'off'
- platform: state
entity_id: input_select.heatingmode
state: 'Evening'
condition:
- condition: or
conditions:
- condition: template
value_template: '{{ 16 <= now().hour < 21 }}'
- condition: state
state: 'Evening'
- service: climate.set_temperature
data_template:
entity_id: climate.danfoss_z_thermostat_014g0013_heating_1_4
temperature: '{{ states.input_slider.heating_livingroom_evening.state | int }}'
data_template:
entity_id: climate.danfoss_z_thermostat_014g0013_heating_1_3
temperature: '{{ states.input_slider.heating_bedroom_evening.state | int }}'
data_template:
entity_id: climate.danfoss_z_thermostat_014g0013_heating_1_2
temperature: '{{ states.input_slider.heating_office_evening.state | int }}'
- condition: and
conditions:
value_template: '{{ trigger.platform == "time" }}'
- condition: state
state: 'Evening'
- service: input_select.select_option
option: 'auto'
What it does:
I currently have three thermostats that I can control via sliders; each has a slider for day/evening/night settings.
The settings primarily get triggered either at a specific time or by changing one of the sliders.
Of course, changing the evening slider during the day should not instantly trigger the evening automation.
Then there’s a boolean input “ventingmode” that, if set to “on”, prevents the automation from being activated.
(with ventingmode == “on”, all thermostats are set to their minimum temperature settings; useful for opening a few windows when it’s cold outside)
So then there’s cases when I come home early and I’d like the evening settings to be applied before their scheduled time.
For this I now have an input_select control “heatingmode” with values day/evening/night/auto. Auto being the default state.
So I come home and set it to “evening” -> the evening heating settings are applied instantly.
But since I don’t want the heating to be stuck at the evening settings as long as this control is set to “evening”, I reset the control to “auto” when the evening automation would have been activated regularly.
The only thing that needs some more thought is the case when for example the night settings are applied and I decide to stick with “evening” a little longer - the heatingmode control would only be reset when the evening automation would (time) trigger the next day.
