How can i create an automation that runs every hour at a particular time?
**Example: I want Google Home speakers to tell me time every one hour but during daytime only. **
I have the following automation code which announces the time every 1 hour, but it doesn’t announce exactly at 7AM or 8AM , but it says at 8.15AM or 9.30AM every hour based on the automation start time or HA restart time.
alias: 19 Announce Time Every 1 Hour
minutes: /60
platform: time
condition:
after: 05:00:00
before: ‘22:00:00’
condition: time
entity_id: media_player.living_room_speaker
volume_level: 1
service: media_player.volume_set
message: ‘Hey! Now the Time is {{ now().strftime(’‘%I %M %p’') }}. Thank You
service: notify.google_assistant
volume_level: 0.6
Please help
finity
October 9, 2018, 2:52am
2
First off you need to properly format your code according to instructions at the top of the page.
That said try taking off the / in front of the 60. I think that should then match only on the hour every hour.
If not then try 0 instead of 60.
If that doesn’t work then I don’t know.
Edit to add: I think you need to add seconds: 00 also.
See the docs on time triggers.
easwaran83:
This code works fine every 1 hour. I dont think any formatting issue
but not exact at 8 or 9 or 10AM
Use time trigger
Minutes: 0
Seconds: 0
This will trigger every hour at X:00:00
nickrout
(Nick Rout)
October 9, 2018, 6:37am
5
Nevertheless please learn to format your code properly, its like, y’know, good manners.
Tinkerer
(aka DubhAd on GitHub)
October 9, 2018, 11:01am
6
You told it to run every 60 minutes from startup
At least, from what I can work out given you mangled the formatting
finity
October 9, 2018, 12:12pm
7
OK understand that. But try to do what I (and now I see that others) are telling you to try.
Take off the /. Change the 60 to 0.
If it doesn’t work then I’m more than happy to hear “I told you so”.
…and format your code correctly.
