My challenge is to run a heating floor pump only during certain time windows. Say between 06:00 and 20:00 when the inlet temperature and outlet temperature are at a defined level. When the temperature changes within this time window the pump needs to be turned on and off respectively. Turning it on at 06:00 and off at 20:00 is not an option. I’m missing something to get this working. I therefore went into lambda code, but there must be a way to get this working without the lambda code. By the way the lambda code also doesn’t work, but I listed it anyhow to get the idea what I want to achieve.
My first challenge is to get the condition to execute the code only during the time window 06:00 till 20:00.
Hi Mikefila,
That’s also an option, but still not what I’m looking for. My intention is to limited the amount of programning languages as much as possible. Actually make it as simple as possible. By using ESPHome there are many advantages, but need to use the YAML syntax and C++ when going into lambda code blocks. If I could skip the lambda code block or side steps like crontab. Then I could do everything in YAML and it would be perfect for me.
Thank you all for your help. I made the decision for now to continue with both languages. Below is my code which is working fine.
#CV_Floor_Pump
esphome:
platform: ESP8266
board: nodemcuv2
on_boot:
priority: -100 #lowest priority so start last
then:
- lambda: id(Relay01).turn_off();
- lambda: id(CV_Floor_Pump_TemperatureTooHigh).turn_off();
# Enable logging
logger:
level: DEBUG
baud_rate: 115200
# Enable Home Assistant API
api:
ota:
password: "16c2972e32843010a0ebe73ea5698eca"
wifi:
ssid: !secret wifi_ssid
reboot_timeout: 20hours # Reboots for the case that there is no wifi for more than 20 hours
ap:
ssid: "Esp06 Fallback Hotspot"
password: "gSHMN961CTuf"
captive_portal:
time:
- platform: homeassistant
on_time:
- seconds: /30 # needs to be set, otherwise every second this is triggered!
minutes: '*' # Trigger every minute
then:
lambda: !lambda |-
auto time = id(homeassistant_time).now();
int t_now = parse_number<int>(id(homeassistant_time).now().strftime("%H%M")).value();
float temp_in = static_cast<int>(id(CV_Floor_Pump_Temp_In).state);
float temp_out = static_cast<int>(id(CV_Floor_Pump_Temp_Out).state);
if ((temp_in) >= 44)
id(CV_Floor_Pump_TemperatureTooHigh).turn_on();
if (((temp_in) >= 40) || ((temp_out) >= 40))
else
if ((t_now >= 600) && (t_now <= 2000))
if (((temp_in) >= 27) && ((temp_in) > (temp_out)))
id(Relay01).turn_on();
if (((temp_in) <= 25) || ((temp_in) < (temp_out)))
if ((t_now >= 2030) && (t_now <= 2040))
if ((t_now >= 2042) && (t_now <= 2100))
# Define the temperature sensor. In this case the humidity sensor is not used
# CV_Floor_Pump_Temp_In
- platform: dht
pin: D5
temperature:
update_interval: 30s
# CV_Floor_Pump_Temp_Out
- platform: dht
pin: D6
temperature:
#CV_Floor_Pump_Relay
switch:
- platform: gpio
pin:
number: D7
inverted: false
name: CV_Floor_Pump_Relay #by providing a name the Relay01 will become visible in Home Assistant under the name as described by name
#CV_Floor_Pump_TemperatureTooHigh
- platform: gpio
pin:
number: D2 #dummy as there is nothing connected, but needed to automatically create a switch in Home Assistant
# TM1637
display:
platform: tm1637
clk_pin: D4
dio_pin: D3
intensity: 0 # Ranging from 0 - 7
#Make sure that any comment in the lambda code block is started with // as all
# code in the block is C++.
lambda: |-
if (id(CV_Floor_Pump_Temp_In).has_state()) {
it.printf(0, "%.0f", id(CV_Floor_Pump_Temp_In).state);
if (id(CV_Floor_Pump_Temp_Out).has_state()) {
it.printf(2, "%.0f", id(CV_Floor_Pump_Temp_Out).state);
#end code
