OliverH750
(Oliver Harris)
January 23, 2021, 2:47pm
1
I am trying to run a servo with a D1 mini using ESPhome. I followed the example here but it isn’t working. It compiles and uploads, but no entities appear in Home Assistant. I also have a DHT sensor connected and that works fine, but no joy on the servo. Any ideas? My ESPhome yaml is here:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "redacted"
password: "redacted"
ap:
ssid: "redacted"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
ota:
output:
- platform: esp8266_pwm
pin: D3
frequency: 50 Hz
servo:
- id: my_servo
output: pwm_output
- platform: dht
pin: D2
temperature:
filters:
- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: "°F"
name: "Crawl Space Temperature"
humidity:
name: "Crawl Space Humidity"
update_interval: 60s
model: DHT22
and I have this in my config.yaml
input_number:
servo_control:
initial: 0
min: -100
max: 100
step: 1
mode: slider
and this in my automations.yaml
- id: servo
alias: Write Servo Value to ESP
platform: state
entity_id: input_number.servo_control
- service: esphome.crawl_space_servo_control
data_template:
level: "{{ trigger.to_state.state | int }}"
Thanks in advance.
I didn’t get it to work either, any solutions yet?
Youve set your API service as control_servo
and in the automation you use esphome.crawl_space_servo_control
, shouldn’t that be esphome.crawl_space_control_servo
Also, no entities should show up in HA, see the Note on this page:
Hellis81
(Hellis81)
May 19, 2021, 10:57am
4
And remember to power the servo from the power supply directly, there is not enough current in the VCC pin if you use USB.
OliverH750
(Oliver Harris)
May 19, 2021, 12:46pm
5
I forgot that I had posted this. I did get it to work, and it’s been working for months now.
There are actually 2 servos and a sensor. Here is what I ended up with:
api:
services:
variables:
level: float
then:
- servo.write:
- service: control_servo2
variables:
level: float
then:
- servo.write:
ota:
output:
pin: D3
frequency: 50 Hz
pin: D4
frequency: 50 Hz
servo:
- id: my_servo
output: pwm_output
- id: my_servo2
output: pwm_output_2
- platform: dht
pin: D2
temperature:
filters:
humidity:
model: DHT22
geofastit
(Ashwan Saini)
January 14, 2024, 3:57pm
6
This is how I was able to use it.
api:
services:
variables:
level: float
then:
- servo.write:
level: !lambda ‘return level / 100.0;’
output:
pin: GPIO14
frequency: 50 Hz
servo:
output: pwm_output
auto_detach_time: 1s
Configuration.yaml
input_number:
servo_control:
initial: 0
min: -100
max: 100
step: 1
mode: slider
Automation
alias: Spray Servo
description: Spray Servo
platform: state
entity_id:
condition:
service: esphome.esphome_web_33b765_control_servo
level: “{{ trigger.to_state.state | int }}”
mode: single
Finally add card on Dashboard
type: vertical-stack
cards:
type: tile
entity: automation.spray_servo
type: custom:mushroom-number-card
entity: input_number.servo_control
icon_color: teal
fill_container: false
sztuk5
(Sztuk5)
April 12, 2024, 3:12pm
7
Hello. Maybe try to use frendly name (that does not contain spaces). For example in your ESP YAML file:
" esphome:
friendly_name: ESP1 " ← here
This is a name that Home Assistant use and so the name that should be in automations.yaml:
" action:
service: esphome.ESP1_control_servo " ← change the ESP1 if you have set diffrent friendly name earlier.
