Hi
I cant get homeassistant/raspberrypi4-homeassistant:beta or homeassistant/raspberrypi4-homeassistant:dev running on my rpi4
Getting the following errors:
home-assistant-dev | [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
home-assistant-dev | [s6-init] ensuring user provided files have correct perms...exited 0.
home-assistant-dev | [fix-attrs.d] applying ownership & permissions fixes...
home-assistant-dev | [fix-attrs.d] done.
home-assistant-dev | [cont-init.d] executing container initialization scripts...
home-assistant-dev | [cont-init.d] udev.sh: executing...
home-assistant-dev | [cont-init.d] udev.sh: exited 0.
home-assistant-dev | [cont-init.d] done.
home-assistant-dev | [services.d] starting services
home-assistant-dev | [services.d] done.
home-assistant-dev | Fatal Python error: init_interp_main: can't initialize time
home-assistant-dev | Python runtime state: core initialized
home-assistant-dev | PermissionError: [Errno 1] Operation not permitted
home-assistant-dev | Current thread 0xb6f92020 (most recent call first):
home-assistant-dev | <no Python frame>
home-assistant-dev | [cont-finish.d] executing container finish scripts...
home-assistant-dev | [cont-finish.d] done.
home-assistant-dev | [s6-finish] waiting for services.
home-assistant-dev | [s6-finish] sending all processes the TERM signal.
home-assistant-dev | [s6-finish] sending all processes the KILL signal and exiting.
home-assistant-dev exited with code 0
homeassistant/raspberrypi4-homeassistant:stable is running fine
Any idea?
