Running Home Assistant OS on an Rupa RK3566 TV Box (X88 clone) + Installing to eMMC
After a lot of experimentation, I got Home Assistant OS booting and running from internal eMMC on an RK3566-based TV box.
For me the whole project was a weekends experiment - at the same time I saved a lot of money if we compare with the same board configuration (for example Radxa 3 boards are 100€ +)
What even more suprising to me - there were prerry far no customization from my side.
This is not a polished solution yet, but it is usable and surprisingly stable.
Hardware
  • RK3566 TV box (X88-like clone)
  • 32 GB eMMC
  • 4 GB RAM
  • Gigabit Ethernet
  • RTL8821CS Wi-Fi (partially detected)
  • HDMI works
  • GPU works (panfrost)
  • Video decoder node appears
  • HAOS runs normally
Reference to this comment if you need to prepare your board. I have intentionally corrupted Android system to make it load everything that exists in the SD card rather than Android.
1. Prepare HAOS image
I used:
  • Home Assistant OS for Odroid M1
  • .img.xz image
Reason:
Odroid M1 is also RK3566/RK3568 family and already supported by HAOS.
Flash the image to SD card:
xzcat haos_odroid-m1-*.img.xz | sudo dd of=/dev/sdX bs=16M status=progress conv=fsync
(or use BalenaEtcher / Armbian Imager under Windows)
2. Replace DTB
After flashing, mount partition 2 (here you need Linux):
sudo mount /dev/sdX2 /mnt/haosboot
Replace:
rk3568-odroid-m1.dtb
with your own DTB. To find a DTB go to Armbian forum. I used files "rk3566-box-X88PRO20.dtb" and "rk3566-box-demo.dtb" - both worked.
Rename your DTB to:
This is critical. I also added serial console:
sudo nano /mnt/haosboot/cmdline.txt
Changed it to:
console=tty0 console=ttyFIQ0,1500000
3. Boot from SD card
Insert SD card and boot.
At first boot:
  • filesystem expands automatically
  • HAOS takes a VERY long time (50 minutes) - due to the speed of SD card, ~10Mb/s
  • several reboots may happen
  • eventually Home Assistant CLI appears
I initially got:
[Warning] - cli is not started or was interrupted
but after waiting longer it eventually came up. I strongly recommend here to solder into a serial pins of the board / UART and listen. UART will run with a speed 1500000 - not every usb-to-serial will be able to listen to it.
4. Backup recovery
Connect keyboard and run directly on the HA emergency bootup cli:
lsblk
Confirm:
  • SD = mmcblk0
  • eMMC = mmcblk2
  • USB = sda
Before writing in step 5:
dd if=/dev/mmcblk2boot0 of=/mnt/data/mmcblk2boot0.img bs=1Mdd if=/dev/mmcblk2boot1 of=/mnt/data/mmcblk2boot1.img bs=1M
And optionally:
dd if=/dev/mmcblk2 of=/mnt/data/emmc-head.img bs=1M count=64
5. Install HAOS to internal eMMC
IMPORTANT:
Do NOT overwrite the board bootloader area unless you know exactly what you're doing.
I preserved the existing Rockchip bootloader and only wrote HAOS partitions.
Eventually the simplest reliable solution was:
  • boot HAOS from SD
  • use Linux tools directly on the running system
  • write HAOS image to eMMC
  • download .img.xz, unpack that to your usb into .img
Mount USB
mkdir -p /mnt/data/usb
mount /dev/sda1 /mnt/data/usb
ls /mnt/data/usb
Then flash:
dd if=/mnt/data/usb/haos*.img of=/dev/mmcblk2 bs=16Msync
After flashing:
  • remount mmcblk2p2
  • replace DTB again
  • power off
  • remove SD
  • connect Ethernet cable
  • test eMMC boot.
6. Result
Your router should identify the TV board and the board will boot super quick (for me it was 1 minute)
Working:
  • HAOS
  • Docker
  • Ethernet
  • HDMI
  • GPU (panfrost)
  • eMMC
  • automatic partition resize to full 32 GB
  • Supervisor
  • Add-ons
  • SSH
Partially working:
  • RTL8821CS Wi-Fi detected but firmware/init issues remain
Not working yet:
  • front LED/VFD display
  • exact GPIO mapping unknown
Notes
The Odroid M1 DTB contains unrelated front-display definitions (fd628) that do NOT belong to this board.
Do not waste time trying to use those GPIO mappings directly.
The original Android firmware DTBs were almost generic RK3568 EVB DTBs and contained no useful front-panel definitions.
Conclusion
RK3566 TV boxes are surprisingly capable HAOS machines once booted properly:
  • low power
  • silent
  • fast eMMC
  • hardware GPU
  • cheap
The hardest part is DTB compatibility and boot chain quirks.
Once HAOS boots, it behaves almost like native supported hardware. I connected on top a small Noctua fan:
Board photo:
Thanks and references
Thanks for the step-by-step installation guide, which we can easily follow to get this running. Yes, these Android boxes really have a lot of potential and enough power to run Linux and HAOS. I am running a similar setup using Fensoft's image on a Rockchip-based box with an RK3528. My electrical energy consumption and power bill have dropped drastically. (Earlier, I was running this setup on a Lenovo M70q Tiny.) I am trying to get the front display working, but it is beyond my hardware and programming skills. :slight_smile: If you come across anything to make the VFD work, please share. Is the HDMI output working on your box after completing the above steps? Currently, that is the only feature I am missing on the box I am using.
Hi @sri4iot, I was also running HA on Lenovo Thinkcentre Tiny, no ideas how much the power consumption have dropped actually. But this was my goal, to shift the load.
HDMI worked for me natively. If it does not work on your case - check .dtb file, it might be the case thay you used generic or the one that is not 1:1 matches your board.
With a small display - no ideas how to get it running. I tried everything literally everything, I2C scans, SPI, but ut seems like this connection is not configured in .dtb, rather it was managed by some custom software in Android. I have seen people in XDA who made it working - however it is different for each board
Hi @Ovaday, today I tried this method on the x88 Clone box using an SD card with the HAOS 17.3 image and ‘rk3566-box-demo.dtb’. It booted without any hassle. I would like to take advantage of the eMMC, which is 64 GB and faster than the SD card.
In Step 4, Are we taking a backup of the Rockchip boot loader?
In Step 5, you mentioned USB = sda.
Do we need an additional USB drive for this step as well? Do we need to copy the same HAOS image that we used for writing to the SD card (the image the box booted from)?
I know these could be simple questions but I don’t want to risk the bootloader being overwritten. Can you please clarify?
@Ovaday, what motivated you to do this? Is it cheaper? The RAM prices are ridiculous now (like 100eur for 4gb)…
Sorry I missed to ask you this question as well.
You wrote, ‘I preserved the existing Rockchip bootloader and only wrote HAOS partitions.’ However, if I execute dd if=/mnt/data/usb/haos*.img of=/dev/mmcblk2 bs=16M sync, it will overwrite the eMMC completely. How can I preserve the bootloader the same way you did?
Hi @jan-tdy
absolutely cheaper than purchasing some standard RK3566 board
Hi @sri4iot
If I remember correctly, bootloader sits in special partition of the emmc and normally you can’t overwrite if you don’t select this partition.
I can’t remember right now, bit they are called like ‘mmcblk0boot0’ and ‘mmcblk0boot1’ (can differ). Please just backup everything under linux - if something goes wrong you will be able to restore safely and start again.
By the way, I have ported the DTS/DTB for our board, launched NPU (AI usage) and run now immich on top of Armbian. You can take a look into the adjusted DTS here:
Thanks for your reply. I could find the partitions as given below.
➜  ~ lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
mmcblk2      179:0    0 58.2G  0 disk
├─mmcblk2p1  179:1    0    4M  0 part
├─mmcblk2p2  179:2    0    4M  0 part
├─mmcblk2p3  179:3    0    4M  0 part
├─mmcblk2p4  179:4    0    4M  0 part
├─mmcblk2p5  179:5    0    1M  0 part
├─mmcblk2p6  179:6    0   64M  0 part
├─mmcblk2p7  179:7    0    4M  0 part
├─mmcblk2p8  179:8    0   96M  0 part
├─mmcblk2p9  179:9    0  384M  0 part
├─mmcblk2p10 179:10   0  384M  0 part
├─mmcblk2p11 179:11   0   16M  0 part
├─mmcblk2p12 179:12   0    1M  0 part
├─mmcblk2p13 179:13   0   16M  0 part
├─mmcblk2p14 179:14   0    3G  0 part
└─mmcblk2p15 179:15   0 54.2G  0 part
mmcblk2boot0 179:32   0    4M  1 disk
mmcblk2boot1 179:64   0    4M  1 disk
mmcblk0      179:96   0 29.7G  0 disk
├─mmcblk0p1  179:97   0    8M  0 part
├─mmcblk0p2  179:98   0   16M  0 part
├─mmcblk0p3  179:99   0   24M  0 part
├─mmcblk0p4  179:100  0  256M  0 part
├─mmcblk0p5  179:101  0   24M  0 part
├─mmcblk0p6  179:102  0  256M  0 part
├─mmcblk0p7  179:103  0    8M  0 part
├─mmcblk0p8  179:104  0   96M  0 part
└─mmcblk0p9  179:105  0   29G  0 part /var/log/journal
                                      /etc/pulse/client.conf
                                      /etc/hosts
                                      /etc/hostname
                                      /etc/resolv.conf
                                      /run/cid
                                      /run/audio
                                      /etc/asound.conf
                                      /share
                                      /media
                                      /addons
                                      /backup
                                      /addon_configs
                                      /homeassistant
                                      /ssl
                                      /data
zram0        253:0    0    0B  0 disk
zram1        253:1    0   32M  0 disk
zram2        253:2    0   16M  0 disk
If my understanding is correct
  1. I have to add a USB Disk with HAOS image
  2. Take backup of the boot partitions given below to the USB Disk
  3. Proceed with the DD command you have given for writing the OS image to eMMC.
  4. Post successful writing, I have to restore these partitions back to eMMC.
Good to know abut the DTS/DTB. I will follow up with you on the other thread you have mentioned about this. I could see you have lines related to VFD in that config you have shared. Can this be used with this dtb (‘rk3566-box-demo.dtb) to make the front side clock working with the HAOS image?
	openvfd {
		compatible = "open,vfd";
		dev_name = "openvfd";
		openvfd_chars = [04 00 01 02 03];
		openvfd_display_type = <0x00010002>;
		openvfd_dot_bits = [00 01 02 03 04 05 06];
		openvfd_gpio_clk = <&gpio4 RK_PC5 GPIO_ACTIVE_HIGH>;
		openvfd_gpio_dat = <&gpio4 RK_PC4 GPIO_ACTIVE_HIGH>;
		openvfd_gpio_stb = <&gpio4 RK_PC6 GPIO_ACTIVE_LOW>;
		status = "okay";
It depends. Each model has its own way of the front clock implementation. My one is not really discoverable, I don"t know how much time I have even spent on this… The driver is a software implementation
Regarding: mmcblk2boot0 and boot1. You should backup them and never actually touch those partitions.
