I’m basically to 0% free space on my HA Green machine. I’ve started investigation today and came up empty trying to figure out who is doing it.
Here is what I have done so far (thank you ChatGPT for guidance):
du -sh /
says I have 1.2G used in /df -h /
says that 100% is used
Filesystem Size Used Available Use% Mounted on
overlay 28.0G 27.5G 0 100% /
- My estimated database size is only 235.88 MiB
- Next I went to check which docker images I have and result is:
- Docker images are taking a chunk of space (~6.8 GB total), mostly:
- Home Assistant core image: 1.83 GB
- VSCode add-on: 1.06 GB
- Grafana: 815 MB
- Samba: 108 MB
- Supervisor: 434 MB
- Docker containers and volumes are taking very little space — under 200 MB total
- No Docker build cache (0 B)
- No Docker volumes using meaningful space
So only 6.8 GB in docker. Still about 20 GB unaccounted for.
- Searched for big log files or deleted-but-open files
find /proc/*/fd -ls 2>/dev/null | grep '(deleted)' | sort -k7 -rh | head -n 10
returned nothing
du -h -d1 /var | sort -h
returned:
4.0K /var/db
4.0K /var/empty
4.0K /var/local
4.0K /var/mail
4.0K /var/opt
4.0K /var/tmp
8.0K /var/spool
12.0K /var/cache
28.0K /var/lib
496.3M /var
496.3M /var/log
logs are slightly on the big side but not the amount I was looking for.
Next ChatGPT suggested that the space is eaten by Docker overlay storage. Which I have found is in:
/mnt/data/docker
but trying to examine that folder gives me an error that it doesn’t exist. -
Next ChatGPT proceeded to try to get me to get access to that folder through different means, including SSHing to the HA via external terminal. But no success.
I’ve also tried
docker system prune --volumes -a
with no success. And also tried restarting the host machine.
Anything else I can do to clean up my HA Green machine?
