Running scripts from a scene
Hi all,
I am trying to run a script from within a scene.
I have created a script that turns off all the lights in the house, now i want to run that from within a scene.
I want to run it from a scene because i want to use the home assistant complication on my apple watch, and it only seems to display the scenes i have created, not the scripts. Not that i would want to include my scripts in there because it would become a mess.
Can anyone assist?
Why not just create a scene that turns all the lights off?
For the given example it’s not that useful, but i also want to create a scene where the following happens.
Let’s say, in case of a fire or a burglary i want to:
  • Turn on all the lights in the house at full white brightness
  • unlock every door to allow escape routes.
  • Open all the blinds, … that are covering possible escape routes
  • Disable all hardware/software buttons (in case of a detected burglary, they can’t turn off the lights).
    Basically this toggles a switch or something so that every input is ignored.
  • Send out notifications
  • Turn off any power plugs that are potential fire hazards, like the one on my 3dprinter
  • Trigger my NAS to do an immediate shutdown. (not very wise but maybe my data can be saved by rescuing the hardware).
  • Trigger a siren so everybody wakes up.
  • do other stuff that i didn’t even consider yet.
And i want to be able to trigger that from my apple watch, because it is basically always on my person and super easy to trigger.
Or in case of a fire hazard, it needs to be triggered by a smoke detector
I think the scenarios are a bit different: firing from a smoke detector allows you to run a script however you want, while the other scenario is scene-centric because you need to fire it from a complication on your watch.
Regardless, one way you could have your cake and eat it too the way you want would be to use a template device as one of the devices in your scene and just set up that template device to do the things you want (or run a script or whatever). Since the scene is just recording what the current state of a device is then you just include the new template device in your group and should achieve whatever result you want.
So, scene “Panic” might just have a single device, the template device “switch.panic” that, when on, does your list of automations and, when off, reverses it.
Alright, i will definitely look into that template device.
Will keep everyone posted.
