Hey!
Anyone knows if there is a way to run rustdesk as an addon in Home Assistant today?
I think this could be an really amazing feature to let people have temporary access to your HA instance.
For support-like tasks.
Hey!
But why that what the web interface you do every thing from there
Tried to set it up with translateing the github. But i’m kind of lost when it comes to settings.
Have you got it to work @jackjourneyman ?
The purpose is to let someone handle your instance, with the power of only granting access when you want them to have it.
No. Just Googled it.
even after extended tries with AI help, I’ve still not got it working yet.
This works prety great! what tripped you up ? you cant use nginx need to port forward from router to pi/host, 21115-21118 to host ip address. Your Private key is in the logs after 1st install.
