S&P Sabik 350 ventilation system with ESP32 + MAX485 control
Hello comunity,
I was looking for any option how to connect my air ventilation unit with Home Assistant. I couldnt find nothing about connection so I decided create my own. Belive it can help somenone. I have SPCM modul for communication but it uses connectair app and own cloud.
What we need:
  1. S&P Sabik 350 ventilation unit (maybe it works on 210 or 500)
  2. ESP32-WROOM-32D with WiFi and BT
  3. Communication unit MAX485 RS485 to TTL
  4. some cables
  5. working ESP home
  6. working Home Assistant
Setup
  1. first connect ESP32 with MAX485 and Sabik
ESP32 pinout
pinout
MAX485 pinout
pinout
Sabik 350 mainboard
ESP32 MAX485 SABIK 350 modbus RTU
5V VCC
GND GND
GPIO16 DI
GPIO17 RO
GPIO4 DE + RE
A connector 32
B connector 32
  1. install yaml into ESP
Code
esphome:
  name: "your esp name here"
  friendly_name: "your friendly name here"
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  level: DEBUG
wifi:
  ssid: "your SSID here"
  password: "your password here"
  manual_ip:
    static_ip: esp ip here
    gateway: gw ip here
    subnet: subnet here
ota:
  platform: esphome
api:
  encryption:
    key:"your key here"
uart:
  tx_pin: GPIO16
  rx_pin: GPIO17
  baud_rate: 19200
  parity: EVEN
  stop_bits: 1
modbus:
  - id: hub1
    uart_id: modbus_uart
    flow_control_pin: GPIO4
modbus_controller:
  - id: sabik
    address: 1
    modbus_id: hub1
    command_throttle: 200ms
    setup_priority: -10
  - platform: modbus_controller
    address: 4
    register_type: read
    value_type: U_WORD
    address: 5
    register_type: read
    value_type: U_WORD
    modbus_controller_id: sabik
    name: "Extract Air Temperature"
    address: 25
    unit_of_measurement: "°C"
    register_type: read
    value_type: S_WORD
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    name: "Exhaust Air Temperature"
    address: 26
    register_type: read
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "Outdoor Air Temperature"
    address: 27
    register_type: read
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "Supply Air Temperature"
    address: 28
    register_type: read
    value_type: S_WORD
    filters:
      - multiply: 0.1
    name: "Relative Humidity Extract Air"
    address: 29
    unit_of_measurement: "%"
    register_type: read
    value_type: U_WORD
    name: "Relative Humidity Exhaust Air"
    address: 30
    register_type: read
    value_type: U_WORD
    name: "Relative Humidity Outdoor Air"
    address: 31
    register_type: read
    value_type: U_WORD
    name: "Relative Humidity Supply Air"
    address: 32
    register_type: read
    value_type: U_WORD
    name: "RPM Extract Motor"
    address: 61
    unit_of_measurement: "rpm"
    register_type: read
    value_type: U_WORD
    name: "RPM Supply Motor"
    address: 62
    register_type: read
    value_type: U_WORD
    name: "Bypass Damper Position Raw"
    address: 63
    register_type: read
    value_type: U_WORD
    name: "Actual Working Mode Raw"
    address: 90
    register_type: read
    value_type: U_WORD
    name: "Selected Airflow Raw"
    address: 132
    register_type: holding
    value_type: U_WORD
text_sensor:
    lambda: |-
      switch (int(id(communication_error_raw).state)) {
        case 0: return {"No error"};
        case 1: return {"Remote controller error"};
        case 2: return {"Modbus RTU error"};
        default: return {"Unknown"};
    update_interval: 10s
    lambda: |-
      switch (int(id(defrost_status_raw).state)) {
        case 0: return {"Not active"};
        case 1: return {"Active (fireplace defrost)"};
        case 2: return {"Active (with pre-heater)"};
        case 3: return {"Active (unbalanced airflows)"};
    name: "Bypass Damper Position"
    lambda: |-
      switch (int(id(bypass_damper_raw).state)) {
        case 0: return {"Closed"};
        case 1: return {"Open"};
        case 2: return {"Error"};
    update_interval: 5s
    name: "Actual Working Mode"
    lambda: |-
      switch (int(id(actual_working_mode_raw).state)) {
        case 0: return {"Snooze"};
        case 1: return {"Low speed"};
        case 2: return {"Medium speed"};
        case 3: return {"High speed"};
        case 4: return {"Boost"};
        case 5: return {"Auto (humidity)"};
        case 6: return {"Auto (VOC)"};
        case 7: return {"Auto (0-10V)"};
        case 8: return {"Boost in auto"};
        case 9: return {"Weekly 1"};
        case 10: return {"Weekly 2"};
        case 11: return {"Weekly 3"};
        case 12: return {"Weekly 4"};
    update_interval: 5s
    lambda: |-
      switch (int(id(selected_airflow_raw).state)) {
        case 0: return {"Manual (low)"};
        case 1: return {"Manual (medium)"};
        case 2: return {"Manual (nominal)"};
        case 3: return {"Auto"};
        case 4: return {"Snooze"};
    update_interval: 5s
    name: "Active Alarm Status"
    lambda: |-
      if (id(active_alarms).state) {
        return {"Alarm Active"};
      } else {
        return {"No Alarm"};
    update_interval: 5s
    name: "Filter Alarm Status"
    lambda: |-
      if (id(filter_alarm).state) {
        return {"Alarm On"};
      } else {
        return {"Alarm Off"};
    update_interval: 5s
    name: "Extract Temp Sensor Text"
    lambda: |-
      switch (int(id(extract_temp_status).state)) {
        case 0: return {"Correct"};
        case 1: return {"Error"};
    update_interval: 5s
    name: "Exhaust Temp Sensor Text"
    lambda: |-
      switch (int(id(exhaust_temp_status).state)) {
    update_interval: 5s
    name: "Outdoor Temp Sensor Text"
    lambda: |-
      switch (int(id(outdoor_temp_status).state)) {
    update_interval: 5s
    name: "Supply Temp Sensor Text"
    lambda: |-
      switch (int(id(supply_temp_status).state)) {
    update_interval: 5s
    name: "Extract Fan Status Text"
    lambda: |-
      switch (int(id(extract_fan_status).state)) {
    update_interval: 5s
    name: "Supply Fan Status Text"
    lambda: |-
      switch (int(id(supply_fan_status).state)) {
    update_interval: 5s
    name: "Bypass Active Text"
    lambda: |-
      switch (int(id(bypass_active).state)) {
        case 1: return {"Active"};
    update_interval: 5s
    name: "Boost Contact Status Text"
    lambda: |-
      switch (int(id(boost_contact_status).state)) {
    update_interval: 5s
    name: "Boost Status Text"
    lambda: |-
      switch (int(id(boost_status).state)) {
        case 1: return {"Boost active"};
        case 0: return {"Boost not active"};
    update_interval: 5s
switch:
    register_type: coil
    address: 8
    name: "Allow Automatic By-pass"
    register_type: coil
    address: 9
    register_type: coil
    address: 10
    register_type: coil
    address: 16
    register_type: coil
    address: 17
    register_type: coil
    address: 26
    name: "Reset Filter Alarm"
    register_type: coil
    address: 1
binary_sensor:
    address: 0
    register_type: discrete_input
    address: 1
    name: "Extract Temp Sensor Status"
    address: 6
    name: "Exhaust Temp Sensor Status"
    address: 7
    name: "Outdoor Temp Sensor Status"
    address: 8
    name: "Supply Temp Sensor Status"
    address: 9
    name: "Extract Fan Status"
    address: 10
    name: "Supply Fan Status"
    address: 11
    address: 15
    name: "Boost Contact Status"
    address: 28
    address: 29
interval:
  - interval: 1s
    then:
      - if:
          condition:
            switch.is_on: reset_filter_alarm_switch
          then:
            - switch.turn_off: reset_filter_alarm_switch
select:
    address: 132
    value_type: U_WORD
    optionsmap:
      "Manual (low airflow)": 0
      "Manual (medium airflow)": 1
      "Manual (nominal airflow)": 2
      "Auto": 3
      "Snooze": 4
  1. if is connection correct you will see at logs
[21:52:47][D][text_sensor:069]: 'Boost Status Text': Sending state 'Boost active'
[21:52:47][D][text_sensor:069]: 'Supply Temp Sensor Text': Sending state 'Correct'
[21:52:47][D][text_sensor:069]: 'Bypass Active Text': Sending state 'Not active'
[21:52:47][D][text_sensor:069]: 'Bypass Damper Position': Sending state 'Closed'
[21:52:47][D][text_sensor:069]: 'Extract Fan Status Text': Sending state 'Correct'
[21:52:48][D][text_sensor:069]: 'Actual Working Mode': Sending state 'Boost in auto'
[21:52:48][D][text_sensor:069]: 'Supply Fan Status Text': Sending state 'Correct'
[21:52:48][D][text_sensor:069]: 'Extract Temp Sensor Text': Sending state 'Correct'
[21:52:48][D][text_sensor:069]: 'Boost Contact Status Text': Sending state 'Not active'
  1. now you can create custom card at homeassistant dashboard. this is only example
code
type: vertical-stack
cards:
  - type: entities
    title: Rekuperácia – režimy a prepínače
    show_header_toggle: false
    entities:
      - entity: sensor.esphome_web_0ba9a0_rpm_supply_motor
      - entity: sensor.esphome_web_0ba9a0_rpm_extract_motor
      - entity: select.esphome_web_0ba9a0_selected_airflow
      - entity: sensor.esphome_web_0ba9a0_actual_working_mode
      - entity: switch.esphome_web_0ba9a0_manual_by_pass
      - entity: switch.esphome_web_0ba9a0_allow_automatic_by_pass
      - entity: switch.esphome_web_0ba9a0_manual_boost
      - entity: switch.esphome_web_0ba9a0_snooze_mode
      - entity: switch.esphome_web_0ba9a0_summer_mode
      - entity: switch.esphome_web_0ba9a0_reset_filter_alarm
        name: Reset filtračného alarmu
  - type: entities
    title: Teploty a vlhkosti
    entities:
      - entity: sensor.esphome_web_0ba9a0_supply_air_temperature
      - entity: sensor.esphome_web_0ba9a0_extract_air_temperature
      - entity: sensor.esphome_web_0ba9a0_outdoor_air_temperature
      - entity: sensor.esphome_web_0ba9a0_exhaust_air_temperature
      - entity: sensor.esphome_web_0ba9a0_relative_humidity_supply_air
      - entity: sensor.esphome_web_0ba9a0_relative_humidity_extract_air
      - entity: sensor.esphome_web_0ba9a0_relative_humidity_outdoor_air
      - entity: sensor.esphome_web_0ba9a0_relative_humidity_exhaust_air
  - type: entities
    title: Stav a diagnostika
    entities:
      - entity: sensor.esphome_web_0ba9a0_selected_airflow
      - entity: sensor.esphome_web_0ba9a0_active_alarm_status
      - entity: sensor.esphome_web_0ba9a0_filter_alarm_status
      - entity: sensor.esphome_web_0ba9a0_bypass_damper_position
      - entity: sensor.esphome_web_0ba9a0_defrost_status
      - entity: sensor.esphome_web_0ba9a0_boost_status_text
  1. enjoy
This is great! Thank you.
I’m thinking of doing this also for our S&P Sabik 500. But it would be the first time to build a ESP32 board. I’m a bit insecure about the cabling (and housing) of the solution.
Could you help me a bit with the cabling? Or do you have a good source to start?
Thank you very much! Works like a charm!
