SAJ Solar inverter
Hello everyone, i have a SAJ H1-6K-S2 that is already integrated in Home Assistant via esolar. (data poll every 5 minutes).
P.S. the inverter is already connected via modbus to a meter (chint DSU666).
After reading some posts i decided to try to reach my inverter via modbus so i can poll data every minutes.
So after I checked out if port 502 of my AIO3 was open (and infact it was) I setted up all modbus parameters in Home Assistant.
The good news is that everything works fine!! I can now poll data from my inverter every 60 seconds!!
The bad news is that every couple days, totally random, the connection via modbus to my inverted drop and i receive on Home Assistant the following error:
2024-05-23 13:00:19.466 DEBUG (MainThread) [pymodbus.logging] Adding transaction 1
2024-05-23 13:00:19.466 DEBUG (MainThread) [pymodbus.logging] Resetting frame - Current Frame in buffer -
2024-05-23 13:00:19.466 DEBUG (MainThread) [pymodbus.logging] send: 0x0 0x1 0x0 0x0 0x0 0x6 0x1 0x3 0x40 0xab 0x0 0x1
2024-05-23 13:00:19.478 DEBUG (MainThread) [pymodbus.logging] recv: 0x0 0x1 0x0 0x0 0x0 0x3 0x1 0x83 0x2 old_data:  addr=None
2024-05-23 13:00:19.478 DEBUG (MainThread) [pymodbus.logging] Processing: 0x0 0x1 0x0 0x0 0x0 0x3 0x1 0x83 0x2
2024-05-23 13:00:19.478 DEBUG (MainThread) [pymodbus.logging] Factory Response[131]
2024-05-23 13:00:19.478 DEBUG (MainThread) [pymodbus.logging] Getting transaction 1
2024-05-23 13:00:19.478 DEBUG (MainThread) [pymodbus.logging] Frame check, no more data!
2024-05-23 13:00:19.478 ERROR (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: modbus-saj: Error: device: 1 address: 16555 -> pymodbus returned isError True
I tried many times to connect via modbus to my inverter again but i always received the same error.
In the meantime I decided to comment (#) the line related to modbus connection from my configuration.yaml
After couple days i tried again to established a connection to my inverter and… everything worked fine!! SO, why I received the error? Why every couple days, totally random, the connection drop and it is immpossible for me reach the inverter via modbus? And why a couple days after the connection drop, if I retry, everything works fine??
Thank you very much!!
Thanks,
I have seen that.
But how connect the modbus to wifi dongle to the inverter.
Do i need unscrew ethernet adapter and can i then connect modbus to wifi dongle?
Hi @pdeneve and @stanus74 thanks for your effort on this - i am also stuck at the same point as @pdeneve
  • can connect a session via python or qmodmaster to the Aio3 but doesnt return any data
  • very different version (firmware = 1.201, hardware = 3.0)
Any other ideas ?
the connection with AIO3 to modbus is not very stable.
I have programmed extra queries in my Home Assistant integration to check the connection in the event of errors and to reestablish it. But it only works for H2/H2S inverters
With a Modbus to TCP converter, the connection is much more stable, e.g. ELfin EE10a
use an Elfin EE10a. I have already tested it with this and the connection is stable and fast
I have also tested this variant with an ESP32 via Bluetooth. It worked similarly to direct via AIO3
Dam, I’ve got an r5 varient three phase and it’s erroring out. And other tips?
the R5 has an RS485 port. You can connect an Elfin EW11 directly. The port supplies 7v on one pin to operate the Elfin without an extra power supply unit.
A Home Assistant integration is available on github
The connection of the pins is also explained there (also on the RS232 port where the AIO3 is normally plugged in)
Thanks finally had my elfin arrive - my inverter also has a DRM port - can i use this?
Hello, i see youre post about modbus
Can u help me?
I have a saj sununo plus 3K-M
And connected Hf Elfin-EE10A
But cant read something.
Can u tell me exactly how u did and what custom component u use?
I tryed saj r5 inverter modbus.
My settings on saj inverter are:
Modbus baudrate: 115200
Adress: 1
Thanks - am so close now. Got a EW11 and have done the correct pinout and setup. Have connnected it to home assistant but all sensors are recording a status unknown - when i check the log everything is successful - are the settings different in an EW11 v EW10?
try change cable RS485_A+ <> RS485_B+
use QModmaster to check whether you can read registers manually.QModMaster - Browse Files at SourceForge.net
Baud rate must be the same everywhere
Check frames counting
If you do not see any send/receive bytes, there are still errors in the settings or cabling
hello,
here also says unknown
i have no errors
inverter is: Saj sununo plus 3m-k
Ok - so getting a timeout
Settings in elfin
what about sent but not recieved?
Swapped the cords over and down I see serial connection frames recieved and transmitterd - but still cant use QMOD master
try these settings
you can also switch Unit 0 to 1 and test again
change the Port in Settings to 502
watch Video (its in spain but you see the settings)
Thanks ive applied those settings - can see below that my computer is connected to it
still getting Timeout error for unit 0 and 1
Ill watch the video now! Feel like im really close! Since there is messaging under the seral port (sent and received) does this mean the error is between the mobus and my home assistant/laptop?
try IP 192.168.86.193
