Samba install not working as expected
I just install the Samba add-on to a fully up to date HA. I filled out the add-on’s Configuration section as so:
Blockquote
Username: SA_HA-PRD-SAMBA
Password: ******************
Wordgroup: WORKGROUP
Enable Compatibility Mode: OFF
Veto files: ._*, .DS_Store, Thumbs.db, icon?, .Trashes
Enable hosts: 192.x.x.0/24
When I start Samba it shows up in the Network devices discovered by my Window 10 PC. However, when I double-click on its icon so that I can be prompted to enter the credentials of my Samba service account, it opens the HA login webpage instead.
Any ideas here for me? The logs read:
Blockquote
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/samba.sh
[11:01:00] INFO: Hostname: PRD0-HA
[11:01:00] INFO: Interfaces: enp3s0
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user SA_HA-PRD-SAMBA.
cont-init: info: /etc/cont-init.d/samba.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nmbd (no readiness notification)
services-up: info: copying legacy longrun smbd (no readiness notification)
added interface enp3s0 ip=X:X:X:X:X:X:X:X bcast= netmask=ffff:ffff:ffff:ffff::
added interface enp3s0 ip=X.X.X.X bcast=X.X.X.X netmask=X.X.X.X
nmbd version 4.16.10 started.
Copyright Andrew Tridgell and the Samba Team 1992-2022
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
making subnet name:X.X.X.X Broadcast address:X.X.X.X Subnet mask:X.X.X.X
create_subnets: ignoring non IPv4 interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
smbd version 4.16.10 started.
uid=0 gid=0 euid=0 egid=0
Processing section “[config]”
Processing section “[addons]”
Processing section “[ssl]”
Processing section “[share]”
Processing section “[backup]”
Processing section “[media]”
INFO: Profiling support unavailable in this build.
s6-rc: info: service legacy-services successfully started
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet X.X.X.X
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet X.X.X.X
run_elections: >>> Won election for workgroup WORKGROUP on subnet X.X.X.X <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet X.X.X.X
Samba name server PRD0-HA is now a local master browser for workgroup WORKGROUP on subnet X.X.X.X
netbios connect: name1=PRD0-HA 0x20 name2=DESKTOP-T2NB9KK0x0
netbios connect: local=prd0-ha remote=XXXXX-XXXXX, name type = 0
Could not find child 156 – ignoring
Thanks,
Ed
Not a valid network. Replace x.x with real numbers
IF you mean you Double-Click HA “Device” in Network, yes you come to HA login-page, because you click on a Device( HA.Webserver ), NOT your Samba-Share , Your Samba-Share’s you can i.e access by “MAP Network-Drive”
From the Documentation ( in SAMBA UI )
Connection
If you are on Windows you use \\<IP_ADDRESS>\, if you are on MacOS you use smb://<IP_ADDRESS> to connect to the shares.
or better as mention “Map Network Drive” ( in windows )
