Samba not available
Dear forum members,
My samba server is not accessible via windows explorer. The SMB protocol is already in good condition, I have already reinstalled the add-on and it still does not work. “could not find the network path.” This is on every PC in my network.
Log
setup_new_vc_session: New VC == 0, if NT4.x compatible we would close all old resources.
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
Could not find child 187 -- ignoring
netbios connect: name1=HASSIO         0x20 name2=GERRITJAN-MONDR0x0
netbios connect: local=hassio remote=gerritjan-mondr, name type = 0
Could not find child 190 -- ignoring
Could not find child 192 -- ignoring
Could not find child 194 -- ignoring
Could not find child 196 -- ignoring
Could not find child 200 -- ignoring
Could not find child 204 -- ignoring
netbios connect: name1=HASSIO         0x20 name2=DESKTOP-C01203C0x0
netbios connect: local=hassio remote=desktop-c01203c, name type = 0
Could not find child 208 -- ignoring
Could not find child 210 -- ignoring
Could not find child 212 -- ignoring
Could not find child 214 -- ignoring
Could not find child 216 -- ignoring
netbios connect: name1=HASSIO         0x20 name2=NIENKEMONDRIA  0x0
netbios connect: local=hassio remote=nienkemondria, name type = 0
Could not find child 219 -- ignoring
Could not find child 221 -- ignoring
Could not find child 223 -- ignoring
Could not find child 225 -- ignoring
Could not find child 227 -- ignoring
Could not find child 229 -- ignoring
Could not find child 231 -- ignoring
Could not find child 233 -- ignoring
Could not find child 235 -- ignoring
Did you try via the IP-address ? \x.x.x.x ?
Yes, I tried that too
Just try it in win explorer. Sometimes the samba share did not show up in the network list.
If you try in explorer use the host name (hassio) of your install.
Does not do it either
Did you allow the hosts in your samba config?
This is my config, password removed of course
"workgroup": "WORKGROUP",
  "username": "GerritJanMondria",
  "password": "********",
  "interface": "",
  "allow_hosts": [
    "10.0.0.0/8",
    "172.16.0.0/12",
    "192.168.0.0/16"
  "veto_files": [
    "._*",
    ".DS_Store",
    "Thumbs.db",
    "icon?",
    ".Trashes"
What’s the IP of your hassio install?
That is 192.168.10.53 (intern)
Are you running HassOS/Hassio or did you install Hassio on Ubuntu ? If on Ubuntu it is the ufw that is blocking access.
Are you able to ping 192.168.10.53 from your clients (computers etc.)?
no Ubuntu FrancisP
Pinging 192.168.10.53 with 32 bytes of data:
Reply from 192.168.10.53: bytes=32 time=3ms TTL=64
Reply from 192.168.10.53: bytes=32 time=2ms TTL=64
Reply from 192.168.10.53: bytes=32 time=10ms TTL=64
Ping statistics for 192.168.10.53:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 10ms, Average = 4ms
Which version of hass.io do you use?
Had the same problem. After adding the following to the config:
"interface": "eth0"
"192.168.178.0/16"
it’s working now.
But the share was not avaibale in explorer under network. So I used \\hassio in explorer. Than I was able to see the folders. After a reboot of the PC, the network drives were available under network.
Version 192
Latest version 192
Can I still use it via WiFi?
Use:
wlan0
and try to change
"192.168.0.0/16"
to
"192.168.10.0/16"
Just asking, why do you prefer WiFi? Reliability and speed are better for a wired connection, and I personally always prefer wired connection whenever possible.
That’s true! :+1:
