Samba Share \root?
I have the Samba Share add-on installed, and can browse the numberous shares on my Windows 11 PC by navigating to \192.168.68.75\ or \homeassistant in Windows Explorer.
What I would like to do is map this to a network drive so I don’t have to manually type it in the address bar each time. But it seems I can only map the individual shares (eg \192.168.68.75\config) to a drive. CoPilot tells me I would have to define a root share with the path "" but I think the Samba Share add-on won’t allow that.
What’s the best way to have my HA file system easily accesible from Windows Explorer on my PC?
Tailscale, zerotier, advanced ssh add-on, among others.
Are you trying to add a drive letter to windoze file explorer?
yes. Or get HomeAssistant to appear in the Network display.
It’s been a few years since I did it, but you can pin the network share folder (even root) in file explorer.
Should be in the right click menu unless win11 messed that up
You cannot map multiple volumes to one drive in Windows.
The problem is (I think), the Samba Share add-on doesn’t define root as a share. And I believe to map a network drive it has to be in the format \server\share
I don’t want to map multiple volumes, I just want to map \homeassistant\ to a drive letter.
It’s not mapped as a network drive. It’s saved as a pinned folder in file explorer. Absolutely no need to mess with samba settings.
Not at my PC right now, otherwise I’d send you a screenshot
This is \homeassistant\ but a. ording to your first post you want more?
Oh, I see. Pin to Quick Access. Yes I suppose I could do that. I would prefer it to be down with the other drives, NAS etc, rather than up in that quick access list, but I suppose it would work.
Ran that same train of thought 6 years ago. Now I instinctively know HA folder location is at the top.
You’ll feel the same in a couple of months :wink:
I’m not sure I quite understand what you mean.
I can map \\homeassistant\addons or \\homeassistant\ssl or any of the other shares as a network drive. But what I would ideally like to do is mount \\homeassistant as a network drive, and then I would have easy access to all those shares.
I mean, I know I can just type that in the address bar, and as ShadowFist pointed out, I can pin it up the top. I just wondered whether there was an easy way to map it to a drive letter.
Never mind. I feel I’m starting to waste everyone’s time here! :slight_smile:
Those look like folders but are separate volumes. They probably are not even subfolders of the root of the drive on homeassistant. I was also confised because homeassistant is the new name of what used to be the config folder.
\\homeassistant is a host
\\homeassistant\config is a volume
\homeassistant is a folder (note the one slash less, this is what you mentioned)
You need the “Windows for Workgroups” addon for HomeAssistant.
Oh wait, isn’t that Samba?
:wink:
I’m not near my Windows machine to see what right click options or sharing to use either.
