SambaNAS + Frigate + HAOS Supervisor issues on startup
I’ve been using SambaNAS to record in Frigate to a secondary drive on my HA host for some time now. I have an automation which added a bit of a delay to allow SambaNAS to startup before Frigate which was working great. Lately however, it seems that HAOS supervisor isn’t updating that SambaNAS is running for quite a few minutes after HA start-up. What’s the best way to speed this up? Or should I try something else to trigger it?
I’ve been trying various different things as I’d like Frigate to start as soon as SambaNAS does thus minimising my camera’s down time. I also want it to not start Frigate if for any reason there’s an issue with the drive as I don’t want to fill the system drive.
I’ve tried forcing HA to reload the supervisor info for SambaNAS but sometimes I think this happens too soon so it doesn’t happen any quicker than it normally does. Also sometimes it will reload it so fast that the next trigger in the sequence has already happened.
- alias: Frigate - Delay start for media mount
  id: Frigate - Delay start for media mount
  description: ""
  mode: single
    - trigger: homeassistant
      event: start
  condition:
    - condition: state
      entity_id: binary_sensor.frigate_full_access_running
      state: "off"
#    - wait_for_trigger:
#        - platform: state
#          entity_id: sensor.home_assistant_supervisor_cpu_percent
#      timeout: "00:05:00"
    - delay: "00:01:00"
    - action: homeassistant.reload_config_entry
        device_id: a5be72009fab739c9228879709344c38 #reloads HA Supervisor SambaNAS integration
#        - platform: state
#          entity_id: binary_sensor.samba_nas_running
#          to: "on"
        device_id: 29dc09920ca372becfbda88d481063b0 #reloads HA System Monitor integration for sensor.disk_use_percent_frigate
    - delay: "00:00:05"
    - choose:
        - conditions:
            - condition: state
              state: "on"
            - condition: numeric_state
              entity_id: sensor.disk_use_percent_frigate
              above: 0
          sequence:
            - service: hassio.addon_start
                addon: ccab4aaf_frigate-fa
        - conditions:
            - condition: state
              state: "on"
            - condition: state
              state: "unavailable"
          sequence:
            - service: notify.mobiles
                title: "Frigate Startup Failure"
                message: "Frigate disk mount has failed"
                  ttl: 0
                  car_ui: true
                  channel: "Important"
                  priority: high
#            - service: notify.gmail
#              data_template:
#                title: "Frigate Startup Failure"
#                message: "Frigate disk mount has failed"
            - stop: "Frigate disk mount has failed"
        - conditions:
            - condition: state
              state: "off"
            - condition: state
          sequence:
                  ttl: 0
                  car_ui: true
                  priority: high
