Hi all,
I have six Xiaomi BLE thermometers around the house, all on stock firmware: 5× LYWSDCGQ (the round one, unencrypted MiBeacon) and 1× LYWSD03MMC (encrypted, using its bindkey).
Setup 1 (years old, works great): two ESP32 nodes running ESPHome with esp32_ble_tracker: and per-device local decoding — xiaomi_lywsdcgq / xiaomi_lywsd03mmc sensor platforms, no filters configured. The decoded values reach HA as native ESPHome entities. Note these nodes are not Bluetooth proxies — there is no bluetooth_proxy: component in their config. Example:
esp32_ble_tracker:
- platform: xiaomi_lywsdcgq
mac_address: XX:XX:XX:XX:XX:XX
temperature:
name: "MJ Salon Temp"
humidity:
name: "MJ Salon Humidity"
battery_level:
name: "MJ Salon Battery"
Setup 2 (new): I recently added some Shelly devices. HA automatically started using them as Bluetooth proxies, and the same thermometers were auto-discovered by the Xiaomi BLE integration with zero configuration. Nice!
The issue: for the same physical device, the ESPHome entity draws a smooth, fluid temperature curve, while the Xiaomi BLE entity (fed through the Shelly proxies) draws a clearly stepped/staircase graph.
Since both paths are decoding the same MiBeacon advertisements (so the payload resolution — 0.1 °C — is identical), my working theory is that the difference is update cadence, not resolution:
- ESPHome’s
esp32_ble_trackerscans continuously and pushes every decoded advertisement to HA, so I get lots of closely-spaced data points. - The Shelly BLE gateway reportedly forwards a given device’s advertisement at most every ~3 s, bundles advertisements, and some users report gaps of over a minute — so far fewer points reach the Xiaomi BLE integration, and the 0.1 °C jumps become visible steps.
My questions:
- Is this analysis correct, or is there something else in the Xiaomi BLE / Bluetooth integration (throttling, deduplication of unchanged values, scanner selection) that reduces update frequency further?
- Is there anything tunable on the Shelly side (BLE observer script parameters?) or in HA to get denser updates through the Shelly proxies?
- If I add
bluetooth_proxy:to my existing ESPHome ESP32 nodes, should the Xiaomi BLE integration entities then update as frequently as my locally-decoded ESPHome entities do?
Thanks!
