Samsung EcoBubble - Display energy by month and current state in "one" card
Hello smart people,
I’ve a stupid samsung washing machine, connected through the SmartThings integrations.
So far, so good.
The integration created 9 entities, out of which, none are realy usable, let me explain:
My washing machine’s name is “Lave-linge” so the entities are
switch.lave_linge (a switch)
sensor.lave_linge_deltaenergy (fluctuating between 0 and 0.1KWh)
sensor.lave_linge_energy (always growing value)
sensor.lave_linge_energysaved (always 0)
sensor.lave_linge_power (always 0)
sensor.lave_linge_powerenergy (always 0)
sensor.lave_linge_washer_completion_time
sensor.lave_linge_washer_job_state
sensor.lave_linge_washer_machine_state
For the last 3, I had to create templates as it is showing irrelevant information when the machine is turned off (see Template, return state as datetime)
But now that HA is Energy-Oriented, I’d like to see like a graph of my consumption by day/week/month
So I want to rely on sensor.lave_linge_energy
sensor.lave_linge_energy         19.1         state_class: measurement
                                              last_reset: 1970-01-01T00:00:00+00:00
                                              unit_of_measurement: kWh
                                              friendly_name: Lave-linge energy
                                              device_class: energy
It was 11.1 end of Jully, it will be maybe 23.7 end of August.
What I’d like is a graph like bar/histogram with KWh as Y-axe and Month as X-axe with 11.1KWh for Jully, 12.6KWh for August ands so on.
Is this something that can be done?
Please help.
P.S.: Note that sensor.lave_linge_energy is increased by sensor.lave_linge_deltaenergy somehow but don’t know how (it is computed by Samsung)
What sensor.lave_linge_deltaenergy looks like
And sensor.lave_linge_energy
One step at a time, I did a utility meter configuration like so
utility_meter:
  lave_linge_energy_monthly:
    source: sensor.lave_linge_energy
    cycle: monthly
Which is good but how do I display it nicely like on the statistic-graph card but by month ?
In python, I wrote a piece of code that generates the graphic I want, based on the statistics table of HA.
I’ve setup a camera on local file and it is working but it is not interractive like I would like.
I’m still pleased by my graphic
But also still sad of the lack of an integrated solution.
I rewrote everything using D3.js, it is close to a normal card, with tooltips and stuffs like that, I’d be happy to give my code to whoever feels able to convert it to a real card.
Here is the result so far:
What I see as parameters for the card:
  • title (obviously)
  • entity_id (the statistic to graph)
  • background_color
  • background_image
  • some other entities in an yaml array, to display as 3 per row (glance card style)
  • entities_position: top or bottom
Who wants to do it for me (us)? Nobody?
This looks really nice man. It’s a shame no one more tech-minded has picked it up, this would be a really nice addition to a lot of dashboards, I’m sure! I’d be curious to know how you got the bar chart up and running, though.
Thx, I’m a developer but not into Python and HA (yet).
Maybe one day I’ll do it myself.
For now, it is kind of painfull
I’ve a D3.js that takes care of every graphical aspect and calls a PHP that get the data from the HA DB.
Everything is hosted where the HA DB is (I mean the webserver I need for that but it could be dramatically be simplified by using python and the HA primitives directly)
And if you want to see how it is now, more than a year after, it is like so
That’s why it is important to highlight the current month because everything after is from last year.
I did it using the statistics-graph card (and a bit of card-mod to remove the legend)
  - chart_type: bar
    period: month
    days_to_show: 365
    type: statistics-graph
    entities:
      - entity: sensor.lave_linge_energy_monthly
    stat_types:
      - state
    card_mod:
      style:
          ha-card {
            border: none;
        .content statistics-chart $ ha-chart-base $: |
          .chartLegend {
            display: none;
But I lost functionalities that I liked in the battle:
  • highlight of current month (darker and last but not quite the same)
  • figures at the top of the bars
  • Nice tooltip (the existing one is not clear)
By the way, if someone knows how to change the current month color using card-mod, I’ll be very grateful.
It’s a big mistake - waiting for a card-mod solution in “non-card-mod” threads )))
I know but my first intention was to do it without card-mod. Now that I gave up on my solution as well as the help of someone to implement it, I’m using that standard card and tried card-mod to get closer to my liking.
I want to break down what I did to get to the last step (mostly in French but you should get to the point).
Prerequistes: SmarThings integration up and running
First, create some utility meters
utility_meter:
    cycle: monthly
  lave_linge_energy_daily:
    cycle: daily
  lave_linge_energy_weekly:
    cycle: weekly
Second, create some templates to display the current status, time and more (I’m aware that it is old style, I was young, please forgive me, one day I’ll come back to those and simplify)
    sensors:
      samsung_prog_state:
        friendly_name: 'Etape du programme'
        value_template: >-
          {% set statuses = { 'weightSensing':'Détection du poids', 'wash':'Lavage', 'rinse':'Rinçage', 'spin':'Essorage', 'finish':'Terminé' } %}
          {% set status = states('sensor.lave_linge_washer_job_state') %}
          {{ statuses[status] if status in statuses.keys() }}
        availability_template: >-
          {{ iif(is_state('sensor.lave_linge_washer_job_state', 'none') or is_state('sensor.lave_linge_washer_job_state', 'unavailable'), 'false', 'true') }}
      samsung_machine_state:
        friendly_name: 'Machine à laver'
        value_template: >-
          {% if is_state('sensor.lave_linge_washer_machine_state', 'run') %}
            Marche
          {% elif is_state('sensor.lave_linge_washer_machine_state', 'pause') %}
            Pause
          {% else %}
            Arrêt
          {% endif %}
        icon_template: >-
            mdi:power-plug-outline
            mdi:pause
          {% else %}
            mdi:power-plug-off-outline
          {% endif %}
      samsung_washing_time:
        friendly_name: 'Fin du programme'
        device_class: timestamp
        value_template: >-
          {{ states('sensor.lave_linge_washer_completion_time') }}
          {{ iif(is_state('sensor.lave_linge_washer_job_state', 'none') or is_state('sensor.lave_linge_washer_job_state', 'unavailable'),'false','true') }}
Finally, everything is there to do the card:
It is a vertical-stack-in-card, a custom card that is available in HACS
To ease my work, I always start with a vertical-stack as it is UI compatible:
  1. Glance card
type: glance
title: Samsung EcoBubble
entities:
  - entity: sensor.samsung_machine_state
  - entity: sensor.samsung_washing_time
    icon: mdi:clock-outline
  - entity: sensor.samsung_prog_state
    icon: mdi:debug-step-over
  1. statistics-graph
chart_type: bar
period: month
days_to_show: 365
entities:
stat_types:
  - state
If, like me, you dont like the legend of the statistics-graph card, use card-mod to remove this part (you can find the full card above)
card_mod:
  style:
      .chartLegend {
        display: none;
  1. Another glance for the energy summary
type: glance
entities:
  - entity: sensor.lave_linge_energy_daily
    icon: mdi:calendar-today
  - entity: sensor.lave_linge_energy_weekly
    icon: mdi:calendar-week
    icon: mdi:calendar-month
Then, to convert the vertical-stack into the vertical-stack-in-card, edit the card in yaml and replace type: vertical-stack with type: custom:vertical-stack-in-card
