I’ve just added a Samsung BRB260087WW fridge/freezer to an existing Smartthings integration (by @andrewsayre) in 0.97.2
Three sensors show up in HA, but they never update in either States or in the frontend. I can see in the log that HA is at least receiving open/close status for the doors, even if the state of the relevant device never changes.
In States:
binary_sensor.refrigerator_contact off friendly_name: Refrigerator contact
device_class: opening
binary_sensor.refrigerator_filterstatus off friendly_name: Refrigerator filterStatus
device_class: problem
sensor.refrigerator_temperature_measurement unknown friendly_name: Refrigerator Temperature Measurement
device_class: temperature
In the frontend:
Log:
2019-08-23 13:47:36 DEBUG (MainThread) [homeassistant.components.smartthings.smartapp] Subscriptions for app 'xxxxxxxx-xxxx-xxxx-xxxxx-xxxxxxxxxxxx' are up-to-date
2019-08-23 13:49:07 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'xxxxxxxx-xxxx-xxxx-xxxxx-xxxxxxxxxxxx', 'device_id': 'xxxxxxxx-xxxx-0000-0000-000000000000', 'component_id': 'main', 'capability': 'execute', 'attribute': 'data', 'value': {'payload': {'id': '0', 'x.com.samsung.da.openState': 'Close'}}, 'data': None}
2019-08-23 13:49:07 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'xxxxxxxx-xxxx-xxxx-xxxxx-xxxxxxxxxxxx', 'device_id': 'xxxxxxxx-xxxx-0000-0000-000000000000', 'component_id': 'main', 'capability': 'execute', 'attribute': 'data', 'value': {'payload': {'id': '1', 'x.com.samsung.da.openState': 'Open'}}, 'data': None}
2019-08-23 13:49:35 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'xxxxxxxx-xxxx-xxxx-xxxxx-xxxxxxxxxxxx', 'device_id': 'xxxxxxxx-xxxx-0000-0000-000000000000', 'component_id': 'main', 'capability': 'execute', 'attribute': 'data', 'value': {'payload': {'id': '1', 'x.com.samsung.da.openState': 'Close'}}, 'data': None}
Any ideas or should I raise and issue on Github? Thanks.
