This is normal for some Samsung model as the Lan port is switched off when the TV is in Standby. You have 3 options if this is the case (from the one I know) :
use libcec from a raspberry connected by hdmi to the TV for exemple
use an other device like Xbox, chrome cast… . You can switch on the TV when this kind of devices connected to TV hdmi is switched on
use infrared device like the brodlink to play IR command.
Hope it could help.
@yaazzz,
No i did not receive a request to connect an external device on the TV.
Below are the logs
18-10-14 19:45:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 20:15:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 20:45:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 21:15:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 21:45:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 22:15:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 22:45:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 23:20:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-14 23:55:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 00:30:39 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 01:00:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 01:30:37 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-10-15 01:30:37 INFO (MainThread) [hassio.addons.git] Update add-on https://github.com/home-assistant/hassio-addons repository
18-10-15 01:30:37 INFO (MainThread) [hassio.addons.git] Update add-on https://github.com/hassio-addons/repository repository
18-10-15 01:30:39 INFO (MainThread) [hassio.addons] Load add-ons: 46 all - 0 new - 0 remove
18-10-15 01:30:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 02:00:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 02:30:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 03:00:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 03:30:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 04:05:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 04:40:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 05:15:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 05:45:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 06:15:40 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 06:45:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 07:15:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 07:30:37 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-10-15 07:30:37 INFO (MainThread) [hassio.addons.git] Update add-on https://github.com/hassio-addons/repository repository
18-10-15 07:30:37 INFO (MainThread) [hassio.addons.git] Update add-on https://github.com/home-assistant/hassio-addons repository
18-10-15 07:30:38 INFO (MainThread) [hassio.addons] Load add-ons: 46 all - 0 new - 0 remove
18-10-15 07:45:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 08:20:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 08:55:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 09:30:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 10:05:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 10:35:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 11:05:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-10-15 11:07:56 INFO (SyncWorker_11) [hassio.docker] Run command 'python3 -m homeassistant -c /config --script check_config' on homeassistant/raspberrypi3-homeassistant
18-10-15 11:09:02 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-10-15 11:09:02 INFO (SyncWorker_13) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 11:09:07 INFO (SyncWorker_13) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 11:09:10 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.79.3
18-10-15 11:09:51 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-10-15 11:12:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:12:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:12:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:12:40 INFO (SyncWorker_4) [hassio.docker] Run command 'python3 -m homeassistant -c /config --script check_config' on homeassistant/raspberrypi3-homeassistant
18-10-15 11:13:45 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:13:45 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:13:45 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:13:46 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-10-15 11:13:46 INFO (SyncWorker_0) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 11:13:51 INFO (SyncWorker_0) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 11:13:53 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.79.3
18-10-15 11:14:34 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-10-15 11:15:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:15:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:15:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:15:37 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:15:37 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:15:37 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:15:58 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:15:59 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:15:59 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:16:42 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:16:42 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:16:42 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:17:22 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:17:22 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:17:22 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:17:41 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:17:41 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:17:41 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:18:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-15 11:18:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-15 11:18:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-15 11:18:59 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
18-10-15 11:18:59 INFO (SyncWorker_15) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-10-15 11:19:01 INFO (SyncWorker_15) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.79.3
18-10-15 11:19:41 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-10-15 11:30:37 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-10-15 11:30:37 INFO (MainThread) [hassio.host.info] Update local host information
18-10-15 11:30:37 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
18-10-15 11:30:37 INFO (MainThread) [hassio.host.services] Update service information
18-10-15 11:30:37 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
18-10-15 11:35:42 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
Sorry to bring this back up, but did you manage to do something about this problem?
I do have this TV and when i check HA it shows if the TV is on or off, but I can’t control it via HA. It’s like i can only see if it is on or off. nothing else.
