SamsungTv Integration Model NU7090 not supported
Hi All, from the versione 105.3 the integration with samsungtv is changed, so if i use the integration menu retrive the error “Model not supported” then if i use the manual configuration the Tv not find in the component.
samsungtv:
#NU7090 (port must be set to 8801, On/Off, MAC must be specified for Power On)
  • host: !secret samsungtv_ip
    port: 8801
can you help me ?
I have the same problem, this model appears as supported in the integrations page but then a message appears that is not.
Regards,
