Hi there,
is there a way to get values from climate.set_temperature stored in InfluxDB? Apologies, noob here. I assume it’s not working since it’s a service and not a sensor, but struggle to find a solution online. I do tell InfluxDB in config yaml to include the domain “climate” but I can’t get a card in frontend or Grafana to display the set temperature.
Any ideas?
The set’ temperature is stored in the temperature
attribute of a climate entity.
You can see it in the history of the climate.
i don’t know how grafana stores that data, but you can create a template sensor from that attribute.
template:
- sensor:
- name: "Climate set temperature"
unit_of_measurement: "°C"
state: >
{{ state_attr('climate.your_climate', 'temperature') }}
Thank you so much. That did the trick!
