Hello to all,
I searched the forum and found some similar questions, which give different answers. Maybe some are outdated.
I want use a theme which should be selected on startup per default:
I added this to my configuration.yaml:
The theme file *.yaml I put in the (new) folder “themes” in my config-folder.
Now I can select the theme in my profile. I changes immediately. So far so good.
But when I shutdown the server and restart it the setting is on “Backend-selected”, my theme selection wasn’t saved. Should this work as I expect ?
That’s weird. If you use incognito mode or turn on some settings, stuff like that may not be saved to your browser. If this keeps happening, add an automation like this:
