Apparently this is a lot harder than meets the eye!
I’d like to create a seemingly simple automation (I see I’m not the first):
→ Scan this NFC tag
→ Jump to a dashboard
(Real life use case: when you scan the NFC tag you get taken to a dashboard with a bunch of button cards controlling HVAC and lighting for that room specifically).
I tried adding something like this in YAML:
description: "Scan this tag and jump to the office HVAC dashboard"
mode: single
- platform: tag
tag_id: 12121212-121212-1231212-
condition: []
action: []
alias: Tag exitgateway is scanned
tap_action:
action: navigate
navigation_path: /office-control-dashboard
… but I can’t get HA to accept it!
Another option I considered is just writing the dashboard URL straight to the tag but … that then opens it in the browser (and requires separate authentication).
Apparently what I’m looking for (with this approach) is a deep link but … I haven’t had success.
My client / device is an Android and I’m running the standard/stock HA app.
interesting puzzle. i don’t have a perfect solution for you, but a couple things that might help…
what about pushing an actionable notification to the device. the user would have to tap on that notification, but then it can take the user straight to a page with the controls you want.
i presume you can’t count on the home assistant app already being visible? you could otherwise use browser_mod to do a popup with a page of your choice.
For those coming here in search of a solution, here what worked for me. This solutions opens the app and the desired dashboard ONLY on the phone who scanned the NFC!
Came here to say that I had some trouble with this and found this to work for me:
alias: Tag Area - Loft (Desk) is scanned
description: ""
triggers:
- trigger: tag
tag_id: <your tag id>
conditions: []
actions:
- action: >-
notify.mobile_app_{{ device_attr(trigger.event.data.device_id,
"name_by_user") }}
metadata: {}
message: command_webview
command: /dashboard-loft
mode: single
I originally named the device “Nick’s Phone” but the actual device ID was formatted “nick_s_phone” so simply calling the attribute “Name” results in “Nick’s Phone”. Changing the name in the UI doesn’t change the original device id (maybe someone know something I dont) but if you change the name in the UI under settings>devices & services>mobile app and use “name_by_user” you can match the format it is expecting. Note I had to physically scan the tag to test otherwise trigger.event.data.device_id is not generated. I also have only tested this on an android device.
