Scene creation error in tuya
scene creation of current for over load which aprox if its overload current is 8amps so if the current gets reduced to 7.5amps it will off the device. but if the power resumes and the current is less then 8 amps in the start itself (exp.7.5) its not getting off. it will run in dry run and motor it damaged.
